AMP for DT 1990 PRO
IkBeNbEn
Hey sow i did some research on amp's and dac's because I want to invest in audio but after 2 days i still have no idea wat to get.
I was looking at one
https://www.amazon.com/SMSL-M6-Converter-Headphone-Silver/dp/B06X92M8MS?ref=TA_GL_POS_16&tag=kixstar-20&sigts=1550319334193&sig=9c1f44a47d5a833f2c58e3e2d9a585c9405a9613&adId=B06X92M8MS&linkCode=tw1&ref-refURL=https://taos-na-prod.amazon.com/viewer&imprToken=92d3e09c-ee2d-4292-8219-ae3c09fa2fc4)
Sow is this a good one and should I get a dac or something else?
ps: sorry for the bad english.
That amp is pretty weak.
32Ω 130mW
64Ω 270mW
150Ω 220mW
300Ω 120mW
That's a pretty substantial amplifier @pizapower. My HD8 DJ's are 95 ohm headphones and they could run off a cheap little FiiO e10k, plus SMSL is a pretty well respected brand. Though @IkBeNbEn I would instead recommend this https://www.ebay.com/itm/Schiit-audio-Modi-2-and-Magni-2-combo-w-adapter/233131349905?hash=item3647b61791:g:UIcAAOSwxy5cYzEz:rk:2:pf:1, unsure if you live in America or not but 169.99$ for this setup is a damn good deal.
The Louvre
Lian-Li PC-O11 DW   |   ZOTAC RTX 2080   |   Core i5 9600k   |   SeaSonic FOCUS Plus 650W Platinum   |   MSI MPG Z390 Gaming Pro Carbon  |  2x16Gb TRIDENT Z ROYAL  |   2xSX8200 240Gb NVME SSD's  |   1x Seagate Firecuda 1TB   |   EVGA Closed Loop Cooler 280mm   |   1x MSI MPG27C Monitor
