vega 64 power mod
Go to solution Solved by Madgemade,
I think it is. You will need to find the powerplay tables registry file. It will be online somewhere. All it does is change some settings in the driver so it should also work for the 64, as long as someone has made a file.
does anyone know if the unlimited power mod available for the vega 56 is also available on the 64?
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1033984-vega-64-power-mod/
Gaming Rig:CPU: Xeon E3-1230 v2¦RAM: 16GB DDR3 Balistix 1600Mhz¦MB: MSI Z77A-G43¦HDD: 480GB SSD, 3.5TB HDDs¦GPU: AMD Radeon VII¦PSU: FSP 700W¦Case: Carbide 300R
https://linustechtips.com/topic/1033984-vega-64-power-mod/#findComment-12303337
thxxxx
https://linustechtips.com/topic/1033984-vega-64-power-mod/#findComment-12303381
