Need some help changing thermal paste
You do the opposite of taking it apart, which is what you just did.
Add new paste then put it back together....
you should add more paste than you would do on a CPU, since the cards doesn't use a IHS and any thermal paste is in direct contact with the die. so it is critical for all the die to be covered bij the paste.
