Atypical triple monitor setup.
Tcfj
I have been kicking around the idea of of adding two 4:3 or 5:4 monitors to the sides of my 24 to run as a gaming setup as well as work flow. I know the cringe many of you have on the thought of such a jank design, but if it can work it would fit my budget and my space much more efficiently than three 16:9 screens that I could not afford. I have found that 19 inch monitors at 5:4 are about as close as it gets in height, (20 in at 4:3 would be a bit closer I think but I can't seem to find any made with displayport which I need to make this work.)
My problem is the native 1280x1024 I am unaware if i can have a continuous display that will match up with my 24 in 1080 display. Now I can count, but I just wanted to ask the brain trust that is this forum if anything can make this work properly outside of dropping my resolution on my main display. although I may still try. I'm not picky about gfx, all about the gameplay.
I have done a 4:3 as a second monitor on W10.  It works fine.  You can set resolutions independently, you just hit a "wall" moving your mouse at the very bottom of the screen lol, have to mouse UP, then left to get it on the 2nd screen.  Besides that, you're good to go.
Do what your budget and space will allow.
Main Rig:
Case: Lian Li Lancool Mesh RGB
CPU: Ryzen 5 3600
Cooler: CoolerMaster MasterLiquid 240
MB: MSI B550 Gaming Pro Carbon
Ram: Gskill DDR4 3600 x 32GB
GPU: Asus Arez Strix Vega 64 OC
PS: Seasonic FOCUS Gold Plus Series SSR-750FX
SSD1: Crucial P1 1TB NVME
SSD2: Adata SU800 512gb M.2 Sata
HDD: Hitatchi 2tb 7200RPM + 3x 2TB WD Passport USB 3.0
Monitors: AOC C24G1
Keyboard: Cheap Blue Knockoff Mechanical
Mouse: Uhuru Gaming Mouse
OS: Pop! 21.04
Current Vintage Equipment:  Please ask me about it, I love to talk old tech!
IBM Thinkpad 390, IBM Aptiva A12, IBM PS/2 Model 25-004.  Compaq Contura 4/25C, Presario 7596
Asus P5A-B Socket 7 Box, Tandy 1000RLX-HD "B" & 1200-2FD, VIC20, Zenith ZFL-181-93, Packard Bell 300SX.
Apple II/gs, Mac Plus x2, Mac SE x2, Performa 450
Yes you can mismatch monitor resolutions, although pixel size (physical) should be identical if you want to be able to have continuity of image between the screens like for gaming).  If it's not you'll get one screen that effectively looks magnified vs. the others.
(I'm telling you this from a machine using 2 1440 screens and 1 1080 screen...all are 27").
Workstation:  14700nonk || Asus Z790 ProArt Creator || MSI Gaming Trio 4090 Shunt || Crucial Pro Overclocking 32GB @ 5600 || Corsair AX1600i@240V || whole-house loop.
LANRig/GuestGamingBox: 9900nonK || Gigabyte Z390 Master || ASUS TUF 3090 650W shunt || Corsair SF600 || CPU+GPU watercooled 280 rad pull only || whole-house loop.
Server Router (Untangle): 13600k @ Stock || ASRock Z690 ITX || All 10Gbe || 2x8GB 3200 || PicoPSU 150W 24pin + AX1200i on CPU|| whole-house loop
Server Compute/Storage: 10850K @ 5.1Ghz || Gigabyte Z490 Ultra || EVGA FTW3 3090 1000W || LSI 9280i-24 port || 4TB Samsung 860 Evo, 5x10TB Seagate Enterprise Raid 6, 4x8TB Seagate Archive Backup ||  whole-house loop.
Laptop: HP Elitebook 840 G8 (Intel 1185G7) + 3080Ti Thunderbolt Dock, Razer Blade Stealth 13" 2017 (Intel 8550U)
