Yes it will but at full load you will experience system freezes or reduced performance, so dont recommend using it. Unless it's a really good quality PSU. You will almost never be using up the full TDP of all parts at once.
So should i use if i am not goning full tdp at any time.will it shorten the life time of the psu?
https://linustechtips.com/topic/103328-will-work/#findComment-1382481
