Since 2011 I’ve been using an old Gateway all in one PC with only 4gb of ram and an underperforming CPU with integrated graphics.
Im finally building a new PC this year. I’m going to use it for 144hz 1080p gaming, video editing, and streaming if I can.
I bought an I5 8600k and 16 GB of 3200 MHz ram (it was on sale for 100 at the time). My power supply is a used EVGA Supernova 750 G-2  (probably overkill for my build but it’s too late to return it).
I’m still waiting on money for a graphics card but I’m looking for 1070 - 1080 like performance for around $350 USD.
The RTX 2060 or the GTX 1660ti are my main choices right now, but I have also been looking at used 1080’s, 64’s, and 1070ti’s.
This is my first build so i’m trying to stay away from used graphics cards though (I don’t know enough to diagnose problems).
Any suggestions?
https://linustechtips.com/topic/1032874-first-pc-build/
new RTX 2060. best choice for the gpu right now.
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
https://linustechtips.com/topic/1032874-first-pc-build/#findComment-12292522
2060 or Vega 56 (with Samsung memory) would be your best choices
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
https://linustechtips.com/topic/1032874-first-pc-build/#findComment-12292528
For 350 2060 i guess, if you think 1660ti would perform as fast, i don't think so.
2060 have 400 more cuda cores, that alone can make a huge difference.
https://linustechtips.com/topic/1032874-first-pc-build/#findComment-12292535
6 minutes ago, Normanbates4 said:
vega 64
you can get a vega 56 and flash it to 64 for free.
https://linustechtips.com/topic/1032874-first-pc-build/#findComment-12292573
Any suggestions?
I would personally go for a last gen card. The RTX cards are to pricey because of Ray Tracing. A feature few will ever actually use. Go for a 1070TI, 1080. And if you can, try to find a watercooled one, or a hybrid cooler, so you can overclock it to get better performance.
Also, if its not too late, i would return the Intel CPU and MOBO and go for a Ryzen 5 2600X. I normally wouldnt reccomend this, but with your want of streaming and video editing, those extra cores and threads will come in handy. https://cpu.userbenchmark.com/Compare/Intel-Core-i5-8600K-vs-AMD-Ryzen-5-2600X/3941vs3956
EDIT: WHATEVER YOU DO, DONT BUY AN AMD CARD. I'm an amd fanboy all the way, but dont buy a VEGA card.
"If you gon be bout it, be bout it bout it" ~ Gavin 'itsjusta6' Simon
I play games - Look at my profile for specs
I love memes. I make bad memes, but I like dank memes, who doesn't?
I am good at editing videos and pictures, feel free to message me if you would like some work done.
Thanks!
Kole Overby
Owner At:
Chaos Network
DanTheNali Videography
Employee At:
Neighborhood Mechanic
Heinen's Powersports
https://linustechtips.com/topic/1032874-first-pc-build/#findComment-12292610
Why? RX 580/570 are better options than GTX 1060/1050 Ti, Vega 56 is cheaper than 2060 in quite a few places and they perform roughly the same overclocked, even power consumption won't be that much higher.
Ex-build:
Meshify C – sold
https://linustechtips.com/topic/1032874-first-pc-build/#findComment-12292686
Did i say dont buy an RX card? NO. I said dont buy VEGA
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
https://linustechtips.com/topic/1032874-first-pc-build/#findComment-12292694
You also said "WHATEVER YOU DO, DONT BUY AN AMD CARD". RX 5XX is AMD card, as well as RX Vega
Ex-build:
Meshify C – sold
https://linustechtips.com/topic/1032874-first-pc-build/#findComment-12292702
OK, you can buy an RX 4 or 5 series card. just please, DONT BUY VEGA.
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
https://linustechtips.com/topic/1032874-first-pc-build/#findComment-12292719
Again, why?
Ex-build:
Meshify C – sold
https://linustechtips.com/topic/1032874-first-pc-build/#findComment-12292793
Again, why?
Vega. Is. Bad.
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
https://linustechtips.com/topic/1032874-first-pc-build/#findComment-12292802
