ATM i have Corsair H80i v2 as exhaust (in the back), and 2 front coolers that came with the case.
Does my H80i function as a case overall exhaust or just CPU's?
Do i need to buy another cooler? A 140mm top cooler perhaps?
Case: Corsair Carbide SPEC-OMEGA Black/Red
PSU: Corsair TX750M
Motherboard: ASUS ROG STRIX X299-E GAMING
CPU: Intel I7-7740X
CPU Water Cooler: Corsair H80i v2
GPU: ASUS DUAL-O8G GeForce GTX 1070
RAM: 1x Kingston HyperX FURY 8GB 2666Mhz DDR4
HDD: Seagate SATA 3,5" BarraCuda 1TB
SSD: Kingston 2.5" 240GB A400
https://linustechtips.com/topic/1032812-is-my-cooling-enough/
Cooling depends on what specific CPU you're using and if you're overclocking. I'm assuming you're using the 7740x. The cooler should be enough. As long as you're staying below 80C, you're totally safe. Anything above and I'd start becoming nervous (although no damage would occur).
The H80 would work as an overall exhaust; however, it wouldn't be the best.
What temps do you have while playing games? Like I said above, as long as you're not hitting 80+, you're totally good. Even if you are, you're still probably fine.
If you're looking for an upgrade regardless, I'd always recommend a cooler like the Dark Rock Pro 4 or the Noctua D15 over any 140 or 120mm AIO. They perform comparably to 240/280mm radiators and have a lower chance of  failure (and generally run cheaper).
Edit: I'd never recommend somebody to use a 120 / 140mm radiator; however, he already hase one and there's no problem unless he's hitting high temperatures.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/1032812-is-my-cooling-enough/#findComment-12291944
Tested on GTA V on 1080p/Max settings and the GPU avg temps seems to be 78C and CPU varies between 68C and 78C (not going 80C or over even in the 1%). I'm not overclocking anything BTW.
Still thinking about a exhaust 120mm or 140mm top fan just to don't let all the exhaust work to the H80i, what do you guys think? Any recommendation?
PSU: Corsair TX750M
CPU: Intel I7-7740X
https://linustechtips.com/topic/1032812-is-my-cooling-enough/#findComment-12292049
You totally can if you want - it may help your temperatures a degree or two.
If you want to choose a fan, you can look through the "fan comparison" link in my signature.
Here are a couple fans compared:
Quote
For minimum noise and alright airflow (list in order from highest airflow to lowest):
Fractal Design - X2 GP-14 (White) 68.4 CFM @18.9 dBa
NoiseBlocker - NB-eLoop B14-2 64.3 CFM @ 16.9 dBa
be quiet! - SilentWings 3 pwm 59.5 CFM @ 15.5 dBa
Noctua - NF-P14s redux-900 49.3 CFM @ 13.2 dBa
NoiseBlocker - NB-BlackSilentFan XK-1 35.3 CFM @ 13dBa
I haven't used the FD's fan, so I'm hesitant to put it on (but the info about it says I should).
All of them are great - it's basically how much airflow you want and which one you like the look of the best.
https://linustechtips.com/topic/1032812-is-my-cooling-enough/#findComment-12292080
Right now you have positive pressure (more intake than exhaust and your exhaust is slightly encumbered) adding a 140mm fan up top will more balance out and create a Neutral pressure environment.  These tend to "leave" hotspots in your case if there are areas in your case that get zero airflow direct from a fan.  Mostly under the GPU if you have a axial fan GPU.
I prefer a high positive or high negative pressure system as these eliminate hot spots efficiently.  If I were you (and I have a ton of case fans ready for situations just like this) I would get better intake fans with better CFM to dBA ratio, and I would absolutely add the exhaust up top as well (if it were me I would mount my Radiator on top and put a real exhaust fan in the exhaust port as this helps to "bring" airflow over the motherboard and CPU VRMs).  More air movement is better than less air movement.
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1032812-is-my-cooling-enough/#findComment-12292099
Adding exhaust wont help with GPU temps. CPU is somewhat normal, though if it has been in use for few years, you could re-seast and reapply thermal paste. Also, if you aren't OCing, you can lower voltages to lower CPU temps.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1032812-is-my-cooling-enough/#findComment-12292938
Case
Since all of the heat from the rest of the components is sucked by the fan and pushed through the radiator
What you could do IF the tube lenght allows you is put it as an intake at the front, so the fan sucks fresh air instead of hot air and cools the liquid instead of warming it
keep the rear fan as an exhaust
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/1032812-is-my-cooling-enough/#findComment-12292988
