I've been looking into buying multiple thin/slim bezel monitors recently for eyefinity but upon research, I discovered that there are no true thin bezel monitors since the viewing image doesn't go all the way to the edge. So I was wondering why there aren't any true thin bezel monitors when TVs already have it?
https://linustechtips.com/topic/103264-thin-bezel-monitors/
A monitor that has the image stretched to the edges is more likely to be damaged during shipping/handling.
https://linustechtips.com/topic/103264-thin-bezel-monitors/#findComment-1381423
The OP is talking about monitors like these where the physical bezel is thin but with an extra masked bezel underneath the glass.
He's trying to find a display without a masked bezel.
https://linustechtips.com/topic/103264-thin-bezel-monitors/#findComment-1381475
TVs don't have any thinner bezel than monitors like the H236HLbid or the U2414H.  Just the size of the TV makes it look thinner.  A 1cm border on a 60" screen will look thinner than a 1cm border on a 24" screen.
Speaking of which, the U2414H has extremely thin bezels (6mm).
https://linustechtips.com/topic/103264-thin-bezel-monitors/#findComment-1381509
Dell U2414H, a true thin monitor.
http://accessories.us.dell.com/sna/productdetail.aspx?acd=12309188680360115&c=us&cid=271006&cs=19&dgc=BA&l=en&lid=4970696&s=dhs&sku=860-BBCG
They are no other ones, beside video wall monitors (those are for commercial purposes, and you require to contact the manufacture for a quote), at least that I know off.
https://linustechtips.com/topic/103264-thin-bezel-monitors/#findComment-1386391
