Hey guys I'm getting an error when I try to press a button in my "app" that is supposed to begin running the code on another .lua file called level1.lua but it is giving these errors.
the code it is referring to is
local playBtn
-- 'onRelease' event listener for playBtn
local function onPlayBtnRelease()
	-- go to level1.lua scene
	composer.gotoScene( "level1", "crossFade", 500 )
	return true	-- indicates successful touch
end
But it is saying that the module is not found. Any ideas?
Edit I figured that out now I have this error. I had multiple test prints and it seems to be failing somehow between the end scene:create and start of scene:show
11:57:09.015  testing
11:57:09.015  testing2
11:57:09.015  testing3
11:57:09.015  ERROR: Runtime error
11:57:09.015  ?:0: attempt to index field 'from' (a nil value)
11:57:09.015  stack traceback:
11:57:09.015      ?: in function 'gotoScene'
11:57:09.015      C:\Users\Charles\Documents\Corona Projects\Powell Animation\menu.lua:15: in function '_onRelease'
11:57:09.015      ?: in function '?'
11:57:09.015      ?: in function <?:190>
Those functions call this file
-- code.lua
local composer = require("composer")
local scene = composer.newScene()
--include physics
local physics = require "physics"
physics.setDrawMode("hybrid")
--Shortcut local variables
local screenW, screenH, halfW = display.actualContentWidth, display.actualContentHeight, display.contentCenterX
function scene:create(event)
	local sceneGroup = self.view
	print "testing"
	--start physics
	physics.start()
	physics.pause()
	--Creates the background with color
	local background = display.newRect(display.screenOriginX,display.screenOriginY,screenW,screenH)
	background.anchorX = 0
	background.anchorY = 0
	background:setFillColor(0)
	print "testing2"
	local spaceship = display.newImageRect("Sunglasses_Emoji.png",90,90)
	spaceship.x,spaceship.y = 160, -160
	physics.addBody(spaceship, {density =2.0, friction = 0.0, radius = 30})
	--create 8 obstacles
	sceneGroup:insert(background)
	print "testing3"
end
function scene:show(event)
		print "testing4"
	local phase = event.phase
	if phase == "will" then
	elseif phase == "did" then
		--Add my animation here
		--perhaps two ships moving through asteroid objects
		physics.start()
	end
end
function scene:hide(event)
		--when code is on screen
		--code here runs when whole scene is off screen
		physics.stop()
	end
end
function scene:destroy( event )
    -- Code here runs prior to the removal of scene's view
    package.loaded[physics] = nil
	physics = nil
end
scene:addEventListener("create",scene)
scene:addEventListener("show",scene)
scene:addEventListener( "hide", scene )
scene:addEventListener( "destroy", scene )
return scene
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
https://linustechtips.com/topic/1032506-lua-module-not-found/
