How to get front panel 'push clips' out on enthoo primo?
Solved by Melt My GPU,
Well after all that with an extra set of hands I managed to get it out, all that was required was a small flathead screwdriver to press down the flared tabs on the clip from the backside of the front panel, then after that you can push it out from the back so it comes out the front and you're golden. Then just push in the new clip from the front and it's all good. Kind of like a 5.25 inch bay where you put a device in through the front to get it in and stuff. I'll mark this as solved so hopefully if a primo owner runs into the same problem they'll be able to find this for help.
