I've been trying to configure AccurateRip in EAC with no luck. I have CDs from the list of key discs and a drive that is labeled "Purged" in the CD Drive Offset list, but every time I try and use a key disc, it gives me this prompt about how there are multiple pressings of the key disc, or the drive is wrong, or something like that (it lists multiple reasons, as if it isn't sure of the actual problem). How can I fix this, or what can I do to properly configure AccurateRip? Any feedback is appreciated.
https://linustechtips.com/topic/1031725-eac-and-accuraterip-help-needed/
