Thank you in advance for the help guys and Gals.
System:
I5-2500k
Asus Macimus IV Gene Z
Corsair Vengeance 16gb (CMZ16GX3M4A1600C9)
Evga BR 450W
GTX 1050
Problem:
on main Bios screen it is only showing 8gb ram when i drill down it shows all 4 dim slots populated
in windows resource manager it only shows 8gb installed
in CPU-Z it shows 16gb installed
When i choose XMP profile in bios it refuses to boot and throws error code 59
I have checked to make sure memory is seated  properly, i have also updated bios to newest windows 8 version .
Please any help would be great.
https://linustechtips.com/topic/1031531-please-help-memory-issues/
I would try unplugging the sticks one by one and seeing which two sticks aren't registering. If the two that aren't showing up are in matching colored slots (A1, B1 or A2, B2) it's possible you have a dead RAM channel which could mean a bad motherboard or bad CPU.
Very good point. Might want to check the socket too, make sure that bent pins are a damaged or dirty LGA is the culprit
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Pulsar)
CPU: Ryzen 7 5800X MOBO: MSI MEG X570 Unify RAM: Corsair Dominator Platinum RG(4x8gb) 3200Mhz 16-16-16-32 GPU: EVGA GTX 1080 FTW ACX 3.0 Cooler: Noctua NH-U12S Chromax (LTT Edition) Storage: Intel 6000p 128gb boot drive, Intel 665p 1tb (x2), Samsung 850 EVO 1tb, Case: Phanteks Enthoo Pro M Tempered Glass PSU: EVGA SupeNOVA G1+ 750W OS: Windows 10 Pro 64 bit
FreeNAS Server (The Vault)
CPU: Xeon E5-2603 v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000Mhz 16-18-18-38 GPU: EVGA GT 710 Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 x2 for boot, x16 in RAIDZ for storage, Seagate Ironwolf 2tb (Striped will be a steam cache) Case: Phanteks Enthoo Pro Tempered Glass PSU: Corsair CX750 750W
