Helllo,
Guys I am having this problem that my build is not giving Display . Booting is sured on keybaord but no display at all . I troubleshoot it and found that My GPU Asus GTX 750 PHOC 2GB GDDR5 is the problem here  . Then I used r7 370 and it gives display in no time , at that moment I thought older gpus won’t work but then I used 9500 gt and it also works perfectly . These both gpus were borrowed from my friend And I had to return them . My gpu gtx 750 is also working fine on my older system but not on ryzen build . I tried many things
  • updating Bios of motherboard
  • updating bios of gpu
  • different ram slots
  • Reattached wires and connectors perfectly many times
  • installed ryzen drivers
  • and much more
my Ryzen Build :
AMD Ryzen 5 1400
Asus Prime B350m-A motherboard
8 GB DDR4 2666 mhz Ram
Thermaltake 600w PSU
Seagate 1tb HDD
WIndows 10 64 bit
Viewsonic 1920 x 1080 60Hz LCD
Gigabyte Alpha Casing
Gigabyte  2x 140 mm fans
my Old System:
HP system Amd Phenom ( office build )
first pic while using  AMD r7 370
second one of whole my build with gtx 750
https://linustechtips.com/topic/1031360-ryzen-build-no-display/
