Need Recommendation on New Mouse or Fix for Issue
undrac86
The short of it, I need a better mouse for gaming. One that either will last longer or a fix to help with one I already have.
Need good information on Switches and if I can swap the current ones out of my ROCCAT for something more durable.
    OR
New Mouse
  • Optical
  • Wired Only
  • Height = 3.9cm to 4.2cm
  • Switches don't fail after a year of use
Current Favorite: ROCCAT KONE AIMO (Good Mouse, but main trigger dies after a year of use)
// Notes
I play FPS 99.999% of the time.
I tried looking in the Small-Medium-Large vs Palm-Claw-FTIP. I'm pretty sure I'm and Small to Medium Claw based on what I've read, but applying that knowledge to mice is challenging since I can't look at them physically or try them out.
Notes on the ROCCAT KONE AIMO: It has been a perfect fit for my hands, but the ROCCATS keeps dying after 1 year of use (I think the switches just keep dying). The mouse before that was the ROCCAT KONE and that lasted 6ish months and died for the same reason.
I did like the old Logitech's, but their mice are jumbo sized. I tried the Corsair Glaive RGB but that turned out to hurt my hand (why is there a huge hump in the middle of the mouse), plus the thumb cutout was stupidly designed.
Comfort for me might be the height. The ROCCATs are 4cm +/-0.2cm and I'm not sure what the going rate on Gaming Mice, but yeah... Would something that would last at least 2 years at a time.
Thanks in advance!
PS; I already know optical is better. :P
Edited by undrac86
More Information
17 minutes ago, undrac86 said:
The short of it, I need a better mouse for gaming. I tried looking in the Small-Medium-Large vs Palm-Claw-FTIP. I'm pretty sure I'm and Small to Medium Claw based on what I've read, but applying that knowledge to mice is challenging since I can't look at them physically or try them out.
I currently have the ROCCAT KONE AIMO. Which has been a perfect fit for my hands, but it keeps dying after 1 year of use (Left Click goes out). The mouse before that was the ROCCAT KONE and that lasted 6ish months and died for the same reason. I did like the old Logitech's, but their mice are jumbo. I tried the Corsair Glaive RGB but that turned out to hurt my hand (why is there a huge hump in the middle of the mouse), plus the thumb cutout was stupidly designed.
I think it might be the height since the ROCCATs are 4cm ~.2cm and I'm not sure what the going rate on Gaming Mice, but yeah... Would something that would last at least 2 years at a time.
Thanks in advance!
I have no idea what your question is.  Your ranting like a manicky person. lol
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Thanks in advance!
I *think* I understand, but I need more info. Wireless? Programmable Keys, etc.
We need more info to help.
Unless, you want a flat out random recommendation, in which I would suggest really any Logitech mouse, in particular the G305.
Hope this helps,
-Llama
Ryzen 7 1700X - Cryorig C7 - Gigabyte Gaming B450 Wifi - 16GB GSKILL Aegis DDR4-3000mghz - WD Black NVMe 250GB M.2 / WD Black 2.5 1TB HD - Gigabyte Radeon RX 580 8GB - FD Node 202
"Never trust a computer you can’t throw out a window."
— Steve Wozniak
PCPartPicker - Steam - GitHub
I updated it... Hopefully, it helps get the question across.
