Try setting it to 4GHz at 1.237v in the bios, if it's max boost clock is 4GHz you should easily get stock voltage 1.237v, once you've done that. Fire up Cinebench run that 5 times and if it doesn't crash or freeze move on to Aida64 and run a CPU stress test for about an hour. Make sure you monitor temp's with HWinfo and again if that doesn't blue screen, crash or freeze move on to Handbrake. Once you've got Handbrake open drag and drop a video that's about 20mins long into it and change the video format and increase the Bitrate to 20MBs and click Start Encode. If you don't run into any issue's you've got a stable overclock.
If it does blue screen, crash or freeze bump the voltage to 1.29v and start where it froze, you shouldn't need anymore than 1.29v if 1.237v didn't work.
(◣_◢) Ryzen 5 3600,   Aorus X370 K7,   XPG 16GB 3200,   Gigabyte 2070 Windforce Corsair RM650x,   LG 32GK650F-B 31.5" 144Hz QHD FreeSync VA,   Kingston 120GB SSD,   Samsung 1TB 860 QVO,   2TB HDD,   Fractal Design Meshify C,   Corsair K63 Wireless,   Corsair Gaming M65 PRO,   Audio Technica ATH M50x,   Windows 10 ProCorsair H100x 240mm.  (◣_◢)
(◣_◢) Ryzen 5 1600,   Noctua NH-L12S,   Gigabyte GTX 1060 6G,   ASUS Prime B350 Plus,   HyperX Fury 8GB DDR4 (2666MHz - 1.3v),   SilverStone ET550-B,   Kingston 120GB SSD 2TB HDD,   Cougar MX330,   Windows 10 Pro.  (◣_◢)
