I have 2000 18650 Samsung 20S 18650 cells. I want to arrange them in 100 parallel units making 20 units and 10 units in parallel and 2 of those 10 units in series... Can I do it?.. If I can...then how should I do it to ensure safety and good performance of the batteries and longevity of the cells.
https://linustechtips.com/topic/1030424-offgrid-battery-backup/
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1030424-offgrid-battery-backup/#findComment-12271282
I'm a little confused on your pack configuration. Figure out how many cells you want in series (voltage. Full charged voltage = number of cells *4.2, nominal voltage = number of cells*3.8) and then divide your 2000 cells by that series number to find how many in parallel.
ASU
https://linustechtips.com/topic/1030424-offgrid-battery-backup/#findComment-12272526
My arrangement is shown in the photo...and I thinking of using circuit breakers at the main output lines for example a 500A breaker at thr 14.8v potential line but will a 500A DC circuit breakers work in 14.8V? I know circuit breakers aren't usually tripped by voltage (open circuit) but for 14.8V volts? Will it work? Because I really want to use breakers for their convenience and safety.
https://linustechtips.com/topic/1030424-offgrid-battery-backup/#findComment-12274004
Okay from what I understand, you want 4 different kinds of modules, A-D. A is a 1s300p configuration. B is two A modules in parallel, giving you a 1s600p configuration. C is 2 B modules in series, giving you 2s600p and so on. This sounds way too complicated to me. The first question I have is why have you chosen a 4s configuration? 16.8V (full charge) is not a lot for such a high power system, which will require massive cables to carry your quoted 500A of current.
If this was my system, I would go for like 25s160p system, giving you a much higher voltage, will reduce your maximum current to around 500A. 105v (full charge) at 500A is 52.5Kw. If you're pulling that much power, I bet your battery pack is the last of your issues.
Also look into the homebrew powerwall forum. They have great info on cells, inverters, and everything else you'll need for a system of this scale.
Also for the love of god invest in a good bms.
ASU
https://linustechtips.com/topic/1030424-offgrid-battery-backup/#findComment-12276439
After much thought... I've decided to go with 40 A modules in series and get 148 v and which will lower my current draw to 35 amps
But...what inverter should I use which will give me 5kW of power at 110vac?
And I'll use a custom bms circuit which will be integrated into all A modules ... (Each cell voltage is 3.7v ...so the inverter should not charge them over 4.1v and drain them below 3.2v just to be safe ...now can you give me an inverter which will work from 128 to 164v on the input)
https://linustechtips.com/topic/1030424-offgrid-battery-backup/#findComment-12288010
Look into grid tied inverters, maybe from SMA.
ASU
https://linustechtips.com/topic/1030424-offgrid-battery-backup/#findComment-12290482
the inverter is not going to charge anything, you gonna need a battery management system and a good charger.
Also you should first look for an inverter that fits your needs and then build a battery that fit into the right voltage range.
https://linustechtips.com/topic/1030424-offgrid-battery-backup/#findComment-12300293
Cab you suggest a good high power lithium ion chargers?...
https://linustechtips.com/topic/1030424-offgrid-battery-backup/#findComment-12305249
  • 2 weeks later...
there are many options for this but the question is always what exactly do you want to charge with it and from which source.
first you need to know your final battery voltage and how much power you will get from the source that is charging the batteries only then you can select a suitable charger.
https://linustechtips.com/topic/1030424-offgrid-battery-backup/#findComment-12355777
