27in 144hz VA 1080p Help
Pendragon
I grabbed this list off displayninja. Could someone help me decipher what the differences are between all of these. I'm leaning towards the Viotek GN27C2 right now. The only thing that I've found is the "updated revisions" like the C27FG70 -> 73 and the GN27C -> C2 etc are slightly better. But how or why, no idea.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
Honestly, if I can give you one advice - don't go 27" with a 1080p resolution, IMO for 27" 1440p is the sweet spot and I'd try buying a monitor with that res.
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
it's almost strictly for games or content. I have a IPS 24in 1080p for work and will use the other one in horizontal with vesa mount.
I love 1440p, its just that I don't want to turn down settings to run at 144hz. Right now 1080ti runs almost all games at 1080p 120fps+ stable.
Laptop Main
I have a 1440p monitor (soon two of them) and I also have a 1080Ti, it's a perfectly capable card to run at 144Hz when you have a variable refresh rate monitor. I wouldn't sacrifice quality for performance, even lowering down the settings should provide better image quality and sharpness than 1080p. 27" is just a bit too much for 1080p IMO as the pixels are too visible to me personally...
I used to have 1080p 27" monitor (CFG70), then changed to 1440 27"(CHG70). yes 1440p is so much clearer, but 1080p is still acceptable. anything bigger than 27 will be too blurry for 1080p. I would say 27" is the maximum limit for 1080p.
btw CFG70 is amazing, and CFG73 is just a same monitor with improved stand.
Primary PC
CPU: AMD Ryzen 7 3700X | M/B: Asus ROG Strix X370-F | RAM: G.Skill TridentZ RGB 3200MHz 32GB | GPU: Asus TUF RTX 3070 8GB GDDR6 | SSD: Samsung 960 Evo 250GB | HDD: Seagate Barracuda 4TB x2 | Power: Thermaltake Toughpower 80+ Gold 650W | Sound card: Creative Sound BlasterX AE-5  | Case: NZXT H500 | Cooling: NZXT Kraken X62 | Display: Samsung CHG70 27" 1440p 144Hz QLED
Secondary PC
CPU: AMD Ryzen 5 5600 | M/B: Asrock B450M Pro 4 | RAM: Kingston HyperX Predator 3200MHz 16GB | GPU: Asrock RX 5700 8GB GDDR6 | SSD: Crucial P1 1TB | HDD: WD Black 1TB | Power: Coolermaster Masterwatt 550 | CaseAerocool Cylon Mini | Cooling: BeQuiet Pure Rock Slim 2 | Display: Samsung CFG73 24" 1080p 144Hz QLED
Thanks for reading
That list is  just a basic rundown.
Each monitor will be different to each othe in terms of Color gamut, viewing angles, pixel response, contrast, uniformity, brightness etc etc.
You should check reviews specifc to each monitor ur considering.... full reviews, not just spec rundowns. You want to know exactly how it performs.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
