I've been thinking about upgrading my system (i5-8400, GTX 1050 TI, 16GB of RAM, Asus Tuff Z370 Plus Gaming Motherboard) but I'm not sure which component I should upgrade. I currently play at 1080p and do have games that dip under 60fps like Arma 3, I would like to try and stabilize.
https://linustechtips.com/topic/1030121-system-upgrade/
how much money do you have to work with? if you can, i would say go the 2060 route.
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268516
Right now not enough to immediately go out and buy anything but I recently got a job that's paying me about $400 a week, as I take some time off from college (waiting on a deployment in 2020 or 2021) however my tax return should be looking pretty thick (yes with 2 c's) as I got about $500 last year and I made even less this year so it should be bigger. (in other words besides other expenses I'll have I should have about $800-1k to upgrade). I will also mention that I am currently not using and SSD (though I have one laying around that's a 275GB one) as that will require me to completely reinstall windows and reformat my current 2 HDD. I don't have anything super important document wise, it's just going to be a MAJOR pain in the ass to completely reinstall everything, though I guess it does get me a pretty clean slate from programs I am no longer using.
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268529
well, if we're talking right now I would suggest a 2600/580 combo personally. It's like a 8400 with 2 more cores and a cheaper version of the 1060.
btw, if you do want to go intel, at least get a better board than that
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268541
so, you have ram, a mobo, a good cpu, and a 1050ti.
if you can get to the point of where you can afford it, i would say pick up the 2060 (EVGA Black edition) for 329.99.
if you want to go for a cpu (im guessing you have a stock cooler??) then maybe go for a 8600k if you can afford a cooler like the arctic freezer 34 or 33.
RIP
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268545
i mean, he can avoid upgrading most of his things, but i totally agree with the combo you suggested.
RIP
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268547
true... but I'm not sure what he's using right now... so I just listed the ideal combo for the budget
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268553
@LukeSavenije
so hes got his ram and stuff already
RIP
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268561
Just now, TH3R34P3R said:
@LukeSavenije
He just wants to know out of that what to get better. that’s why I suggested just grab the 2060
im guessing he got a prebuilt, as it smells of a prebuilt system with the configuration.
RIP
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268563
Really? This motherboard (https://www.newegg.com/Product/Product.aspx?Item=N82E16813119037&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-) is really that bad? I've had a great time running my RAM at 3200Mhz, does it just not handle overclocking real well? What about an upgrade to the i7-8700 instead of the Ryzen 2600, considering the fact that I would need a new board for the Ryzen 2600 would the i7-8700 be a better value?
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268567
Just now, LukeSavenije said:
I was aware of that... I'm more thinking about the gpu, cpu, motherboard, case, psu, things like that...
ya lost me luke???
RIP
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268575
the ram isn't really the problem... the vrm's just aren't cooled that well. so yes, it doesn't really overclock on the cpu side. considering you actually have this already, I would suggest upping your gpu to for example a vega 64, if you have the psu for that
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268576
I lost myself too, and found me back
he already has all of this
There ya go ???
RIP
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268581
If currently, all you do is gaming, you probably wanna step up your GPU. It will be a big difference since you don't have the hardware that will potentially bottleneck it. Now if you don't have a monitor that runs higher than 60hz, it might not be worth it.
console.log("way to pro");
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268591
If you want me to be more specific here are my parts (except for the base all I can tell you is that its big enough to fit a 240MM rad at the top and needs to be replaced at some point because I accidently ripped off the top dust cover and destroyed the top front USB cables <---long story)
CPU: Intel - Core i5-8400 2.8 GHz 6-Core Processor  ($184.89 @ OutletPC)
Motherboard: Asus - TUF Z370 Plus Gaming ATX LGA1151 Motherboard  ($133.08 @ OutletPC)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory  ($124.99 @ Amazon)
Storage: Western Digital - Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($44.89 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1050 Ti 4 GB Windforce OC Video Card  ($199.99 @ Amazon)
Power Supply: EVGA - 500 W 80+ Certified ATX Power Supply  ($39.99 @ Amazon)
Total: $772.72
Generated by PCPartPicker 2019-02-05 12:08 EST-0500
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268604
Total: $772.72
So, 2 things. Get a nice crucial MX500 500gb m.2 drive. 67.99 can get it for as low as 50 when it’s on sale. Get your os moved to that, you will feel a night/day difference.
Second, grab either a rx580 or a RTX2060. Both will fix your FPS problem.
And maybe 3rd, pick up a 144hz monitor (for as low as 160) to get a nice jump in gameplay enjoyment from ur new gpu.
RIP
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268609
1 minute ago, RAM555789 said:
So maybe I go with new PSU---->Case---->GPU----->CPU---->240Hz monitor, along with not be a lazy f*** and put in that SSD already?
I’d go: install that ssd—>gpu —>monitor—> case (poor front IO) —> cpu —> PSU (cause it will last for now, it’s not the worst)
RIP
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268618
yeah... I don't fully agree
the 80+ white psu's from evga aren't really that good, and if you're fast, there's a sale on cx(m)'s
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268627
4 minutes ago, RAM555789 said:
that's the mx300... you should get the mx500
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268628
You aren’t wrong ? and yeah. Keep forgetting the CX’s are on sale. It’s why the 450W one is 16 bucks
RIP
https://linustechtips.com/topic/1030121-system-upgrade/#findComment-12268631
