basically i recently just went from a pre built and now i just finished my own build yesterday and it was my first time and i think ive done everything correct installing drivers etc correct but im not to sure cause in every game i play my cpu usage is 90%-100% all the time and my gpu usage is just spiking like crazy going to 100%-50%   100-0% its never stable and i think thats is whats causing my games to stutter sooooo much and low frames and ive tried soo much stuff looking up and nothing works and everytime i install the new 19.1.2 driver i get the 1603 error i done everything they listed and nothing worked so please can someone help me. so now this is my final resort i hope someone can help
PC:
AMD RYZEN 3 2200G Processor
Sapphire Radeon NITRO+ RX 580 8GB Special Edition came clocked at 1430 mhz when i installed it (never overclocked)
ASRock B450M-HDV AM4 DDR4 mATX Motherboard
Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3200MHz C16
ADATA Ultimate 120GB SSD
Vs550w 80+
https://linustechtips.com/topic/1029679-need-help-really-badly/
um... are you plugged into the port on the graphics card and not the motherboard?
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
https://linustechtips.com/topic/1029679-need-help-really-badly/#findComment-12264449
I smell a bottleneck. That isn’t really a good CPU/GPU match up. Alternatively, it may be running games on the IGpu instead
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1029679-need-help-really-badly/#findComment-12264454
yeah thats what i was suspecting that it was on the igpu, so it was killing the cpu. but it is a bottleneck regardless.
RIP
https://linustechtips.com/topic/1029679-need-help-really-badly/#findComment-12264458
What games does this happen in?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1029679-need-help-really-badly/#findComment-12264470
2 minutes ago, Tempis said:
this is the gpu i got it has a 8 pin and a 6 pin and i do have both connected but should i sell this one and get 1 with just 1 pci cable needed ? would that kill the bottle neck
No that's not what the problem is. What you should try doing is changing graphics settings, high to low, and find out what games nake it a little easier on the CPU. A consistent 50 is better than a drop to 30.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1029679-need-help-really-badly/#findComment-12264496
i play all my games on the lowest settings possible at 1080p
https://linustechtips.com/topic/1029679-need-help-really-badly/#findComment-12264503
crank it up, your GPU is probably able to draw so many frames but your target is only 60
Primary PC:
PSU tier list
https://linustechtips.com/topic/1029679-need-help-really-badly/#findComment-12264510
ive tried every setting possible low medium high and custom same thing all the time 90%-100% cpu usage but gpu usage is never stable goes from 100 to 30 100 to 0 it random up down up down non stop
https://linustechtips.com/topic/1029679-need-help-really-badly/#findComment-12264514
well the ryzen 3 2200g can handle black ops 4 at smooth 60, so you need to try various settings to get it working. What else do you have open in the background
Primary PC:
PSU tier list
https://linustechtips.com/topic/1029679-need-help-really-badly/#findComment-12264529
Just now, Theguywhobea said:
There is not much you can do other than a CPU upgrade to help with your bottlenecking issue.
Online tests show that the 2200g can handle BO4 so something does actually seem wrong
Primary PC:
PSU tier list
https://linustechtips.com/topic/1029679-need-help-really-badly/#findComment-12264531
