Hey guys,
I have an issue when I go to do some work on the PC or need to fully power down.
I press the on/off switch on the PSU and it makes a crackling, arcing like sound. The sort you might hear on an in line light switch.
I am guessing it's because the 5v rail is still drawing power to keep the system in standby.
Whenever I turn off in this way, It needs to boot twice on next startup and I often see Error 41 in error logs.
The PSU makes no unusual sounds in normal operation.
I have everything from, it's completely normal to RMA NOW ?
Any views?
Thanks.
https://linustechtips.com/topic/1029602-power-supply-switch-crackle/
The Corsair RM?
You shut down your PC but it doesn't fully shut down? try disabling hibernation
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
How often are you turning the PSU off at the back of the PSU unit? Why are you turning it off at the back of the unit?
Whenever I need to do work on the system. Replace parts, cable manage etc. It's been through a few builds in this case and PSU. Only just started noticing the crackle though.
55 minutes ago, 191x7 said:
The Corsair RM?
It is the Corsair RM850x how did you know? That might be a good idea. I heard it draws power anyway, just to be in standy. Using poswer from the USB's still plugged in.
Should be fine. Don't worry about it.
