https://linustechtips.com/topic/1029417-cant-tell-the-difference-help/
different sellers for the same card.
Primary PC:
PSU tier list
How many watts do I need?
"Cheaper" is Amazon Us listing, watch out for import fees if you're in EU.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
Just now, Jitendra said:
Both the graphic card are same just the two different seller are selling them
I found a reburished version on ebuyer for £530, Is it worth going it or shall I get the new one?? - https://www.ebuyer.com/875093-exdisplay-msi-geforce-rtx-2070-gaming-z-8gb-graphics-card-ebr2-rtx-2070-gaming-z-8g?mkwid=sWA3N2WiH_dc&pcrid=51630194939&pkw=&pmt=&gclid=CjwKCAiAv9riBRANEiwA9Dqv1XpjFY2Udpizh8SB7CRlXqq_puaFCaIw0lENUVZQJ64ChQOPWoOlsBoC7tYQAvD_BwE
4 minutes ago, Tevildo said:
I can't tell you the exact answer as i hadn't bought any refurbished  GPU but If you are getting warranty on it then definitely you can go with
8 minutes ago, Tevildo said:
Just looked and there are 3 versions of that card, each one has a higher boost clock, I'd suggest getting the cheapest version of that card, which is also new (found it here; very good seller: https://www.cclonline.com/product/265173/RTX-2070-GAMING-8G/Graphics-Cards/MSI-GeForce-RTX-2070-GAMING-8GB-Graphics-Card/VGA5400/) and just use the auto oc tool in afterburner to get the same perf as the other versions
| Ryzen 7 3700x | 16GB Vengance @ 3200 | MSI GTX 1070Ti Gaming |
| ADATA XPG SX8000NP 256GB Nvme SSD + WD Blue 500GB SSD | 4TB WD Blue |
     | Corsair RM650x |
| NZXT H200 White |
