So i am still trying to decide what GPU to get, I will be running a 31.5" 1440p 75hz monitor with freesync.
I will be playing some first person shooters and racing games, (Battlefield V, Need for Speed, COD)
I will also want to be able to transcode 4k HEVC on the fly to 1080p h264 on plex probably 2-3 streams max, I know nvidia has a cap of 2 streams.
I will be using the card probably 30% gaming but when i do would like to stay around 60fps or better on high detail.
I been considering vega 56 but not sure if i want to go with that old of card, also been looking at 1070 and 1070ti and rtx 2060.
My budget for a card is going to be about $400-425 max am considering buying used as well.
I know the rtx 2060 loses vram and rtx doesn't really seem worth it right now and once it does i thing the 6gb frame buffer at 1440p is going to be lacking going forward.
I want the card to be quick at transcoding on slowest to get best file size and quality.
Thanks for your thoughts.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1029095-help-choosing-a-gpu-for-scratch-build/
get a 2060 its about the same as a 1070ti except 2gbs less vram
(◣_◢) Ryzen 5 3600,   Aorus X370 K7,   XPG 16GB 3200,   Gigabyte 2070 Windforce Corsair RM650x,   LG 32GK650F-B 31.5" 144Hz QHD FreeSync VA,   Kingston 120GB SSD,   Samsung 1TB 860 QVO,   2TB HDD,   Fractal Design Meshify C,   Corsair K63 Wireless,   Corsair Gaming M65 PRO,   Audio Technica ATH M50x,   Windows 10 ProCorsair H100x 240mm.  (◣_◢)
(◣_◢) Ryzen 5 1600,   Noctua NH-L12S,   Gigabyte GTX 1060 6G,   ASUS Prime B350 Plus,   HyperX Fury 8GB DDR4 (2666MHz - 1.3v),   SilverStone ET550-B,   Kingston 120GB SSD 2TB HDD,   Cougar MX330,   Windows 10 Pro.  (◣_◢)
yea, i just see the rtx series being a bust not sure if i want to get wrapped up into that right now. I might wait to see what the gtx 1660 has to offer.
Internet Connection
Passmark Score
3dmark Score
Network
