30 minutes ago, fihtingox said:
but my laptop has some port on the bottom, and i don't know if that is the ram slot, and if it is I don't wanna use it.
Could you post a picture of this "port"? You're probably looking at the docking port. You'd have to take the bottom of the laptop off to see the RAM slot.
~Air Cooling Advocate~
https://linustechtips.com/topic/1028763-i-need-help/#findComment-12257196
Visit Crucial.com and put in your Dell Model.  It will tell you how much RAM you can use.
The Memory banks should be right next to eachother.  There is a chance the 2nd bank is little tricky and you have to move something to get better access.
Make sure you install / remove the sticks on a slanted angle
CPU i7 4960x Ivy Bridge Extreme | 64GB Quad DDR-3 RAM | MBD Asus x79-Deluxe | RTX 2080 ti FE 11GB |
Thermaltake 850w PWS | ASUS ROG 27" IPS 1440p | | Win 7 pro x64 |
https://linustechtips.com/topic/1028763-i-need-help/#findComment-12257293
