Hi Guys
Thanks for all your help so far my system is finaly getting therer after got my graphics card picked and ordered (1060 for £100 used looks legit but that's what PayPal is for)
I have a lot of space in my case and a couple of spair pcie ports free and i feel a need to fill the space (that and the boot drive is only a 128gb ssd)  I'm thinking RAID
Would someone be able to link me some video that are a bit more than just how it works
And
If i use raid 5 cand i use 2 1tb hdds and one 2tb  of some ourher combernation of the primary totaling the secondary not looked at drive prices in years
And
Is a used ssd something i should avoid?
The budget is £80
https://linustechtips.com/topic/1028620-raid-help/
5 minutes ago, james844 said:
Hi Guys
And
And
The budget is £80
I usually don't recommend raid. backing up your data regularly removes the need for it.
But if you want to run raid, you should really run it with identical disks. IE: 3x 1TB drives, 2x 2TB drives, 4x 2TB drives, etc.
And I would avoid used SSDs unless you have a way to see the write count and how much warranty it has left.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/1028620-raid-help/#findComment-12256031
Thanks i'm just wainng a challenge that results is faster data RAID 0 and cloud
https://linustechtips.com/topic/1028620-raid-help/#findComment-12256056
