Hi all !
I'm currently running a GTX 980 windforce and earlier today while i was ripping down the dirt tracks in dirt rally my display went blank. I restarted the system and the display output was wrong. The post screen wasn't full screen, the text was blurry, then the BIOS image looked like it had over-scan on, then after the windows logo there was no signal. I proceeded to inspect the card physically for any damage (Oh yeah, i should probably mention that I was testing out an overclock of 100Mhz on GPU and 400Mhz on Vram (That was maybe over kill ?‍♂️ ) ). While inspecting i dissemble the heat sink (Interesting thing when i disassembled the heat sink is that the VRAM pads fell appart, who know's how old this card is), no apparent damage. I then plugged the HDMI in (No heatsink) just to see it post, and what do you know it's back to normal. I reapplied thermal past everywhere, the Vrams seem to be close enough to the heat sink for it to be cooled with thermal past, temps are fine etc...
So really the question here is, has anyone had a similar experience ?
What could be the problem with the DVI output ?
Thanks
Fred
https://linustechtips.com/topic/1028563-gtx-980-windforce-dvi-out-problem/
I'd try a different DVI cable, and/or a different DVI monitor before you make conclusions about the port being dead. But if the card is old enough, and the DVI port was used enough, then it could be possible that the DVI port just gave up on life.
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
Yeah but the cable i'm using is the still the same HDMI to DVI-I
  • 2 weeks later...
