Which 2k ultra wide for 2080ti?
Olli_
Hi all
I am looking for a 2k UltraWide around 34” to use with a 2080 ti. My budget is around £650 I would like to have 100hz if possible and a ips screen.  I have seen this one https://www.scan.co.uk/products/34-asus-designo-curve-mx34vq-uwqhd-monitor-3440x1440-219-1800r-60hz-4ms-30001-100m1-3x-hdmi-dp?gclid=Cj0KCQiA1sriBRD-ARIsABYdwwEyZ13ydPYdVOf_DEeBGC_tDrQO_M5HA8siKE95gIS5wZXeAZEKRKAaArO7EALw_wcB and also https://www.scan.co.uk/products/34-dell-ultrasharp-u3415w-curved-ips-3440x1440-300cd-m-2m1-5ms-speakers-dp-in-dp-out-minidp-hdmi-mhl?gclid=Cj0KCQiA1sriBRD-ARIsABYdwwH9CMoxNDN-czipsw92RY04krNt8gc2SSHvHz-kd_iQ9-s5R17o9UwaAtgHEALw_wcB I know it’s 60hz  but I like the look of it. Are there many others within the price range that you would recommend? The monitor will be used for art/productivity and gaming
Thanks in advanced.
35 minutes ago, Olli_ said:
Hi all
I am looking for a 2k UltraWide around 34” to use with a 2080 ti. My budget is around £650 I would like to have it if possible and a ips screen.  I have seen this one https://www.scan.co.uk/products/34-asus-designo-curve-mx34vq-uwqhd-monitor-3440x1440-219-1800r-60hz-4ms-30001-100m1-3x-hdmi-dp?gclid=Cj0KCQiA1sriBRD-ARIsABYdwwEyZ13ydPYdVOf_DEeBGC_tDrQO_M5HA8siKE95gIS5wZXeAZEKRKAaArO7EALw_wcB and also https://www.scan.co.uk/products/34-dell-ultrasharp-u3415w-curved-ips-3440x1440-300cd-m-2m1-5ms-speakers-dp-in-dp-out-minidp-hdmi-mhl?gclid=Cj0KCQiA1sriBRD-ARIsABYdwwH9CMoxNDN-czipsw92RY04krNt8gc2SSHvHz-kd_iQ9-s5R17o9UwaAtgHEALw_wcB I know it’s 60hz  but I like the look of it. Are there many others within the price range that you would recommend? The monitor will be used for art/productivity and gaming
Thanks in advanced.
that looks pretty dope but i would get a 144hz one imo to take full advantage of a 2080 ti
Damn....
