It depends on what brand you're buying from, but I'd ideally think probably think two strips. There should be dimensions on the Fractal Design website, that might give you an idea of what to look for.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1028150-led-strip-light/#findComment-12251538
1 minute ago, chi_chi_ said:
what brand do u think i should get? money is an facor @mxk.
the dimensions are
395 x 212 x 440mm
I don't usually do RGB strips, since my PC isn't even worth putting RGB strips in.
CableMod, Phanteks, and Corsair are the first brands that come to mind for RGB strips. I'm sure if you look up budget RGB strips you can find something.
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1028150-led-strip-light/#findComment-12251551
ok, thanks i will look into it
https://linustechtips.com/topic/1028150-led-strip-light/#findComment-12251563
Use two 60cm stripes and I cover the inside of my case except where the rear 140mm fan is. So that should be enough for yours. Just need to decide on your type and company.
Using a cablemod kit with the addictional 60cm rgb strip.
https://linustechtips.com/topic/1028150-led-strip-light/#findComment-12253495
