Hello guys, so ive got some problems with my motherboard Msi H55-E33, so I was using 2gb 1333 MHz ram module , and it worked fine, but I got some hynyx memory 2x4 gb 1600 MHz and PC doesn't even want to boot , coolers are spinning ,and led ar working too, I've tried using only 1 module , still same problem, the PC work only with old ram module, doesn't anyone know what I can do  to fix this.
(Sorry for bad English )
https://linustechtips.com/topic/1028094-ram-memory-problems/
Did you reset CMOS? if not that could fix it, the CMOS holds information about your setup that's saved in BIOS, and if you change hardware and don't reset it or set new config in BIOS that could be the problem.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/1028094-ram-memory-problems/#findComment-12251110
