36 minutes ago, Dulan Neelaka said:
Can a b150 motherboard run using a 220v power supply
220v is the AC input from the wall. Whether or not it will work depends on what country you're in and what voltage your houses AC mains power runs.
What country are you in?
What model power supply unit?
What are the specs of your system? (CPU, graphics card)
https://linustechtips.com/topic/1028066-need-help/#findComment-12250932
  • 2 weeks later...
