Hard Drive at 99% Because of pagefile.sys
Solved by Mira Yurizaki,
You can change the page file size by doing:
- Control Panel\All Control Panel Items -> System
- On the left pane, select "Advanced system settings"
- In the dialog that pops up, press the "Settings..." button in the "Performance" section
- In the dialog that pops up, select the "Advanced" tab
- In the "Virtual memory" section, press the "Change ..." button
Set it to whatever you want as long as it's over 1GB. But do not disable the page file.
