Okay. I just want one solid and firm answer for the power draw of a Sapphire Nitro R9 Fury Tri-X 4GB (Non-OC). I have been seeing many different wattages and charts for these and just looking for a single answer. Anyone with this exact card have an exact answer?
How much power does it draw on playing at 1080p High-Ultra games?
https://linustechtips.com/topic/1027100-power/
I mean literally game is different. It even comes down to what exactly in the game is being rendered at any given time. You're asking a question with a million answers.
Fury has a TDP of 275W. On my sapphire Nitro card (pretty much identical to yours), with the performance BIOS on and with my power limit slider maxed out in MSI afterburner, it pulled around 330W from the wall.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/1027100-power/#findComment-12243065
On 1/28/2019 at 10:00 PM, AYDANN6ix9ine said:
Okay. Thanks for the advice.
Here are my games.
Fortnite, CSGO, LOL
Easy games to run, don't expect to be pegged at max GPU load all the time, especially for LoL.
The GPU has 2x8 PCIe plus the PCIe slot, so 375 watts would technically be the max you could push through this card, but I don't believe it reaches that high without furmark's brutal nonsense.
Also, I responded to your other thread with a link, which had a super convenient chart
Try not to make more than one thread about the same topic please.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1027100-power/#findComment-12243086
Be safe.  Go with the highest wattage you see.  Just because one test reports less, does not mean the card is not capable of drawing more.
i9-9900k @ 5.1GHz || EVGA 3080 ti FTW3 EK Cooled || EVGA z390 Dark || G.Skill TridentZ 32gb 4000MHz C16
 970 Pro 1tb || 860 Evo 2tb || BeQuiet Dark Base Pro 900 || EVGA P2 1200w || AOC Agon AG352UCG
Cooled by: Heatkiller || Hardware Labs || Bitspower || Noctua || EKWB
https://linustechtips.com/topic/1027100-power/#findComment-12243091
I've never been able to get my whole system power consumption much over 400w, and I know my 4790k draws over 100w at 4.7ghz. And thats with the Fury overclocked/overvolted, usually I keep her at stock speeds and undervolted.
CPU: INTEL Core i7 4790k @ 4.7Ghz - Cooling: NZXT Kraken X61 - Mobo: Gigabyte Z97X SLI - RAM: 16GB G.Skill Ares 2400mhz - GPU: AMD Sapphire Nitro R9 Fury 4G - Case: Phanteks P350X - PSU: EVGA 750GQ - Storage: WD Black 1TB - Fans: 2x Noctua NF-P14s (Push) / 2x Corsair AF140 (Pull) / 3x Corsair AF120 (Exhaust) - Keyboard: Corsair K70 Cherry MX Red - Mouse: Razer Deathadder Chroma
Bit of an AMD fan I suppose. I don't bias my replies to anything however, I just prefer AMD and their products. Buy whatever the H*CK you want.
---QUOTE ME OR I WILL LIKELY NOT REPLY---
https://linustechtips.com/topic/1027100-power/#findComment-12243099
Is Fury like Vega, where it has too much voltage applied at stock so undervolting it just gives you the same thing but less temps?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1027100-power/#findComment-12243101
Yessir it is. It's a GCN thing in general actually. Even the HD 7000 series undervolts pretty well, as well as obviously the 290(x)/390(x). I can drop 3c by going from stock voltage to -75mv at 1050mhz core.
https://linustechtips.com/topic/1027100-power/#findComment-12243239
