I need help with Sharkoon sharkoon tg5 rgb case
step40
I will build tomorrow my first Pc but i bought this case and there is literally no instructions for the cables.I know the basics how to install motheboard cpu power supply ram and the other components , but i cant find information about these cables with the case...And all the videos ive watched does not show the cables just the installation of all the components which tilts me :D i will need help ,i will post pictures of every single cable aswell.Where do i put these cables?
Listing your specs would help a lot, such as what each item is and it's model number. Please watch a couple youtube videos for "building a pc," "building a pc guide for beginners" or "i've never built a pc before can someone hold my hand because i can't seem to find my manual that came with my motherboard that holds 85% of the answers for the questions I'm asking, even though i may or may not realize that most motherboards have digital copies on their website."
If that last search term doesn't yield any results, just stick to the first two.
These are lighting strips that plug into the RGB hub pictured below.
Quote
Why is this wire in a bag? Maybe show the entire wire?
Quote
All of these plug into the RGB hub that came with the case.
Quote
This is your RGB hub and it plugs into one of your motherboards 4-pin RGB headers. Refer to your manual or list you motherboards model so we can help you find it.
Quote
This is the wire for your power button on your case and it needs to go in the right location otherwise it will not work. You need to look inside your manual for you motherboard as it will tell you where and how it goes. List your motherboard if you cannot find it.
Quote
Those just look like molex adapters attached to another wire. How about taking them off and showing the wire without the adapter.
Quote
I could be wrong but those look like USB 2.0 adapters and need to be plugged into the USB 2.0 header on your motherboard, if your motherboard only has one you may need a splitter or you can just sacrifice a couple USB ports on your case. I can't really tell since I know nothing of what you're using.
Quote
This is the HD Audio for your cases microphone and headphone jacks. They plug into the audio header on your motherboard. Usually located at the bottom left of the board.
Quote
The big adapter is to be plugged in to one of the sata connectors on your power supply, probably for your RGB hub. The other wire looks like it could be an RGB extension or converting cable.
Quote
These go in the same header where the power button that I mentioned above go. these are also important and need to be done correctly. Please refer to your motherboard manual for directions.
Quote
This is a USB 3.0 adapter for your cases USB 3.0 ports and if you want them working you need to plug them into the only header on your motherboard that will accept it. If there's more than one, you get the pleasure of deciding which one you would like to use.
Quote
These also go where your power button wire goes. Refer to manual or most motherboard specs.
Quote
What do these wires go to? are they attached to the same thing?
Quote
All of these get plugged into the RGB hub I mentioned above ^^.
Quote
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
