Hello people
My CPU temperature are way to high i think. Can you please give me some advice what should i do?
PC is not PREBUILT!
CPU: Intel i7 8700 3.20 Ghz
GPU: GTX 1070ti 8 GB
MB: MSI H370M BAZOOKA
RAM: 16GB 2666Mhz
CPU COOLER: STOCK
I have 1 exhaust at the back and 3 fans inhale at front.
First screenshot is idle temperature, second is load(1 game minimized,a lot of tabs on chrome and 2 more programs).
Thanks a lot for any advice! :)
https://linustechtips.com/topic/1025389-my-cpu-temperature/
Why are you still using the stock cooler?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1025389-my-cpu-temperature/#findComment-12227890
I'm assuming that you're using the Intel stock cooler, which explains the high CPU temperatures.
You can undervolt your CPU in Intel XTU (Guide) and/or buy a better CPU cooler (like an Arctic Freezer 33 eSports ONE)
I just build my pc about 1 week ago and im not very good in pc world.
Make sure to quote people when replying to them by clicking the arrow button at the bottom of their posts. Otherwise, they may not see your replies.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1025389-my-cpu-temperature/#findComment-12227903
First lesson:
Intel stock cooler sucks. (No fault of your own, just saying.)
Get a Cryorig H7 or something.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1025389-my-cpu-temperature/#findComment-12227904
Thanks for the advice, and btw im new to the forum and i didn't know appreciate that m8.
https://linustechtips.com/topic/1025389-my-cpu-temperature/#findComment-12227910
The stock cooler is the reason your CPU is running hot. 80C won't kill your CPU, but if you're really worried about it grab an aftermarket cooler.
Cooler Master 212 Evo is a good budget upgrade
Primary PC: - https://pcpartpicker.com/list/8G3tXv (Windows 10 Home)
HTPC: - https://pcpartpicker.com/list/KdBb4n (Windows 10 Home)
Server: Dell Precision T7500 - Dual Xeon X5660's, 44GB ECC DDR3, Dell Nvidia GTX 645 (Windows Server 2019 Standard)
*SLI Rig* - i7-920, MSI-X58 Platinum SLI, 12GB DDR3, Dual EVGA GTX 260 Core 216 in SLI - https://pcpartpicker.com/list/GHw6vW (Windows 7 Pro)
HP DC7900 - Core 2 Duo E8400, 4GB DDR2, Nvidia GeForce 8600 GT (Windows Vista)
Compaq Presario 5000 - Pentium 4 1.7Ghz, 1.7GB SDR, PowerColor Radeon 9600 Pro (Windows XP x86 Pro)
Compaq Presario 8772 - Pentium MMX 200Mhz, 48MB PC66, 6GB Quantum HDD, "8GB" HP SATA SSD adapted to IDE (Windows 98 SE)
Asus M32AD - Intel i3-4170, 8GB DDR3, 250GB Seagate 2.5" HDD (converting to SSD soon), EVGA GeForce GTS 250, OEM 350W PSU (Windows 10 Core)
*Haswell Tower* https://pcpartpicker.com/list/3vw6vW (Windows 10 Home)
*ITX Box* - https://pcpartpicker.com/list/r36s6R (Windows 10 Education)
Dell Dimension XPS B800 - Pentium 3 800Mhz, RDRAM
In progress projects:
*Skylake Tower* - Pentium G4400, Asus H110
*Trash Can* - AMD A4-6300
*GPU Test Bench*
*Pfsense router* - Pentium G3220, Asrock H97m Pro A4, 4GB DDR3
https://linustechtips.com/topic/1025389-my-cpu-temperature/#findComment-12227913
Those temps are crazy high and it is not even full load.  Try to run Aida64 stability test and look at your temps.  Do not dare use Prime95 or any other synthetic stress test as it will kll your CPU and take you to 100c on full load.
He is using stock cooler, that is the first mistake as Grockle88 said.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1025389-my-cpu-temperature/#findComment-12227916
well, can't really blame him if he is a novice builder, but yeah i reccomend Arctic Freezer 33 Esports one edition, should be able to handle your CPU, even with a fair OC
https://linustechtips.com/topic/1025389-my-cpu-temperature/#findComment-12227927
8 minutes ago, Acki said:
Hello people
PC is not PREBUILT!
RAM: 16GB 2666Mhz
CPU COOLER: STOCK
You can try undervolting in Intel XTU (If you are new and you don't want to mess around with your Computer just yet), there are so many guides in YouTube for undevolting and don't worry, undervolting is harmless.
https://linustechtips.com/topic/1025389-my-cpu-temperature/#findComment-12227932
I started this but temperature of some cores was 100C so i stop it.
https://linustechtips.com/topic/1025389-my-cpu-temperature/#findComment-12227949
Looks like your CPU is throttling as it went down to 20 percent and eventually it gives a red screen .. that hardware failure and what not.  So you are not stable at all.  You need to take down your overclock and reduce the cpu voltage.
https://linustechtips.com/topic/1025389-my-cpu-temperature/#findComment-12228117
1 hour ago, Eastman51 said:
The stock cooler is the reason your CPU is running hot...
Its a reason, but voltage is more important here. CPU doesn't need much more than 1.15V to run stock clocks.
I started thisbut temperature of some cores was 100C so i stop it.
Try lowering voltages and maybe reseating cooler first. You need new thermal paste for this. While I do agree that stock isn't really enough for i7 in heavy use, you are still getting bit too high temps than you should.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1025389-my-cpu-temperature/#findComment-12228296
Temps seem fine.
https://linustechtips.com/topic/1025389-my-cpu-temperature/#findComment-12231053
