A upgrade from old system
Go to solution Solved by SorcierX,
Would depend how cheaply you could get a 4770K -- it's older than Ryzen and costs more I believe. ( probably used, if you can even find it ) Honestly if you feel the need to build a new system right now, Ryzen would be the way to go, Intel is more expensive and you don't gain anything.
I want to upgrade my system since its old and i think it does not worth to gey ddr3 1600 mhz 16gb ram for my system right? my ram is 2x4 = 8gb ram.
My budget is 3000 TL ( Turkish Lira)
I mainly want to use it for sony vegas and gaming also some other apps.
What do you think do i really need an upgrade?
If it is possible i really want a intel build once again.
My current system is
CPU:Intel i5 4440 3.1ghz 1150
GPU:Nvidia GTX 1050ti MSI Gaming X
CPU Cooler:Be quiet! Shadow Rock TF2
PSU:Seasonic 520w Bronze 80plus evo edition
HDD:WD Blue ezex 2017 edition 7200rpm 1tb 64mb cache
HDD:Seagate 500gb 5900 rpm 6mb cache
SSD:Corsair Force Le 200 120gb 500 write/read speed
Mobo:Asus H81M-C
Ram:8GB 1600mhz
https://linustechtips.com/topic/1025337-a-upgrade-from-old-system/
are prices inflated in turkey? like gpus... is a rx 580 more than roughly 950 Lira?
@StanicEnemy
Rig 1: i7-9700k OC'd to 5.0ghz all core | EVGA XC RTX 2080Ti | ADATA DDR4 2400mhz 4x8gb | ASUS PRIME Z370-P | Asetek 550LC 120mm | ADATA 480GB SSD & Toshiba P300 3TB | Cooler Master Masterbox MB500 | Win 10 Home | Logitech G910 Orion Spectrum, G502 Proteus Spectrum, G933 Artemis Spectrum Snow Wireless Limited Edition, Corsair MM300 Mouse Pad | 2 MSI Optix Curved 27" FHD Monitors
(before i sold the WD drive and MSI gpu - https://www.userbenchmark.com/UserRun/11946219 171 gaming. felt good.)
Rig 2: i7-7700k Stock clocks | MSI Armor GTX 1070 | ADATA DDR4 2400mhz 2x8GB | MSI Z270 A-Pro | WD Green 240GB SSD & 2TB Seagate HDD | Thermaltake Core G21 Tempered Glass Edition | Win 10 Home | 2 HP Omen FHD 144hz 24.5" Monitors
Rig 3: i7-6700 | GT 730 & GT 645 OEM | Some random DDR4 2133mhz 2x8gb sticks | OEM Dell Mobo | WD Black 2TB HDD & Toshiba 1TB HDD | Win 10 Home | 3 27" Dell FHD Monitors
Rig 4: i7-4770 | EVGA SSC 1050ti | Some random DDR3 ram 2x2gb and 2x4gb sticks | OEM Dell Mobo | Stock Cooler | 1TB WD Black HDD | Win 7 Home
RIP
Rig 5 (dead and dismantled and sold) : i7-7820X OC'd to 4.8ghz all core | MSI DUKE 1080ti | ADATA DDR4 2400mhz 4x8gb | Gigabyte X299 UD4 PRO | Asetek 240mm AIO | WD Green 240gb SSD | Other various components that I can't remember
Rig 6 (same fate as rig 5) i7-8700k stock clocks | MSI DUKE 1080ti | ADATA DDR4 2400mhz 2x8gb | MSI Z370 A-Pro | Asetek 550LC 120mm | WD Green 240GB SSD & Toshiba 2TB HDD | Other various components that I can't Remember
PCPartPicker part list: https://pcpartpicker.com/list/zz9DdX
Price breakdown by merchant: https://pcpartpicker.com/list/zz9DdX/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($164.99 @ Newegg)
Motherboard: Asus - PRIME B450-PLUS ATX AM4 Motherboard  ($104.81 @ B&H)
Memory: G.Skill - Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($139.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 750 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ Monoprice)
Total: $509.78 USD ( 2709.90 TRY )
Generated by PCPartPicker 2019-01-24 11:29 EST-0500
Power supply not needed but recommended due to overclocking the CPU and allow for future upgrades w/o worry. ( completely up to you )
I know you want Intel, but for the money AMD is way ahead at the moment.
CES just happened AMD 3rd Gen Ryzen rumored to launch Summer 2019 - might want to wait to upgrade, maybe even save few more dollars to see what happens when it launches.
Bottom line: Don't buy Intel just cause "Intel" if you're looking to do anything production wise ( video editing ) more cores for cheaper is a better value and you won't lose enough on gaming to notice by going with AMD especially if you take the time to overclock the chip which is relatively safe to do these days.
edit: You can re-use your CPU cooler according to it's SPEC as long as you still have all of the mounting hardware you didn't use.
AsRock X99 Taichi MB // Intel Core i7-6800k Overclocked @ 4.0GHZ // Noctua NH-U14S Cooler // Corsair Vengeance LPX 16GB DDR4 // EVGA GeForce 980Ti SC+ // Samsung 850 EVO 500GB SSD // 2TB WD Gold HDD // Corsair RM850 PSU // Corsair Obsidian Series 750D // Asus VG248QE 144Hz
GIGABYTE GA-Z77X-UD5H LGA 1155 Intel Z77 // Intel Core i5-3570k Overclocked @ 4.2GHZ // Noctua NH-L9x65 Cooler // Corsair Vengeance 16GB DDR3 // EVGA GeForce 960 // 250 GB WD Blue HDD // EVGA SuperNOVA 650 G3, 80+ GOLD // Corsair Carbide Series 100R
@StanicEnemy
RX 580 is 322 dolar here like 1700 Lira.
Thank you so much for explaining everything and build.
You're welcome.
If you wait and get 3rd gen Ryzen it will mostly likely come with a performance boost, but it also might cost a little more, on the other hand the system i posted might actually drop in price a little.
Alright i got it, but something is really keep running in my mind, will it be a wise choice to upgrade my system or should i really upgrade it like last resort?
if you really don't NEED to right now, I'd wait til Gen3 Ryzen comes out, at the very least, but that's the decision for you to make.
