New mobo problems
Go to solution Solved by Constantin,
Do a clean install.....
It can get very messy even if it was working!!!
Recently upgraded CPU, motherboard and ram. Computer turns on, but no connection to the internet,usb drives won't work but cd's do , and computer doesn't turn on/off properly. Usb mouse and keyboard work.
Checked bios and it says ethernet is disconnected. Tried updating bios using their utility but it doesn't update.
Tried updating all files on their cd and it gets stuck on Intel management engine software and a few others I forget which. On the Intel one though it says it's required but I can't install. Gets partway then stops. Tried downloading latest software for this but same thing.
Have to reset by pressing physical reset button. Doing it on the computer just turns the monitor off saying it can't find a signal
Didn't do a clean install. Could be my problem. Dunno.
Intel 8700
Gigabyte b360 gaming 3 wifi
Bios version F6
Please halp.
https://linustechtips.com/topic/1025206-new-mobo-problems/
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1025206-new-mobo-problems/#findComment-12226280
17 hours ago, mxk. said:
Do another clean install and then see how it goes.
Did a clean install and everything is working fine now. Well, Windows does say my product key is no longer valid and won't let me do things like change my background. It is on my old background so I guess it's fine, but it is still annoying I can't get full access to something I bought.
https://linustechtips.com/topic/1025206-new-mobo-problems/#findComment-12229134
Microsoft... Oh well. Just get a cheap copy off of ebay or something. My $12 USD w10 pro is still working.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1025206-new-mobo-problems/#findComment-12229289
Windows product key is tied to your old motherboard. Contact Microsoft and explain you had to change/replace the motherboard.
OEM product keys cannot be transferred, but you might be able to get away with it. Home/retail keys you can re-use.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1025206-new-mobo-problems/#findComment-12229708
After searching everywhere I got a real person from Microsoft in a chat and he fixed everything in a few minutes. All good now :)
https://linustechtips.com/topic/1025206-new-mobo-problems/#findComment-12231856
