The fans:
https://www.amazon.de/Aigo-LED-Lüfter-CPU-Kühler-Luftvolumen-Einstellbare/dp/B07D287JQQ/ref=pd_sbs_147_4?_encoding=UTF8&pd_rd_i=B07D287JQQ&pd_rd_r=ce820c0f-1e65-11e9-84ab-1951b0e8dda2&pd_rd_w=td9wV&pd_rd_wg=zchDh&pf_rd_p=823c2db5-0a4d-474e-99ed-5858cc6a4d7b&pf_rd_r=PJN7F7XAKC2812BF2365&psc=1&refRID=PJN7F7XAKC2812BF2365
Hey all!
I was hoping if anyone could help me out. I'm buying new fans for my pc but I can't figure out what kind of connector it needs. It says 6 pins, but do they mean the 6 pin connector from the PSU?
thx
Jm
https://linustechtips.com/topic/1024835-new-cooling-fans/
These come with a separate controller box that you need to plug them in. That's why they have a proprietary 6pin connector that only fits in the controller box.
https://linustechtips.com/topic/1024835-new-cooling-fans/#findComment-12222772
