Hi guys, I have a galaxy s3 for T-mobile and its running 4.1.1. I am not able to send MMS texts anymore (i was able to for a while). My plan is 1000min talk + unlimited messaging (its a family plan with 2 lines). I also have pay per mb for data.
How do I get my phone to send mms? I have tried to turn on mobile data but it still doesnt work. The toggle for mobile data is also missing in the notification panel. Any ideas?
Also do you guys know any apps that send mms to phone numbers through wifi (for an alternative)? Thanks
Delltopia
Case & Mobo: Stock Dell Optiplex 7010, CPU: i5 3470, RAM: 16gb 1333 DDR3 (1x8gb Corsair Vengence, 2x4gb Random), GPU: Diamond Radeon HD 7970,
PSU: EVGA GQ 650W, SSD: Kingston v300 128gb (OS), HDD: 700gb Seagate 7200rpm (Storage)
https://linustechtips.com/topic/102426-not-able-to-send-mms/
Google hangouts can act as a replacement for the built in messaging system.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/102426-not-able-to-send-mms/#findComment-1369886
but you can't send an picture for example or have a group chat with phone numbers, you need to use gmail accounts.  :mellow:
Delltopia
https://linustechtips.com/topic/102426-not-able-to-send-mms/#findComment-1369895
My Hangouts replaced my normal text sending and I can send normal pictures through SMS with it
https://linustechtips.com/topic/102426-not-able-to-send-mms/#findComment-1369898
i dont know if it will work for what your doing but razer comms is a good alternative to text and calls.and as for the first problem maby call your service provider
I  have GameServer`s And VOIP servers the only price is that you have fun on them.
https://linustechtips.com/topic/102426-not-able-to-send-mms/#findComment-1369903
ill try to get ahold of them. But yea comms is not raelly what i want. thanks tho!
Delltopia
https://linustechtips.com/topic/102426-not-able-to-send-mms/#findComment-1369940
I have the same phone under the same plan. mobile data is toggled under Settings/connections/more networks/mobile networks/mobile data.
Motherboard - Gigabyte P67A-UD5 Processor - Intel Core i7-2600K RAM - G.Skill Ripjaws @1600 8GB Graphics Cards  - MSI and EVGA GeForce GTX 580 SLI PSU - Cooler Master Silent Pro 1,000w SSD - OCZ Vertex 3 120GB x2 HDD - WD Caviar Black 1TB Case - Corsair Obsidian 600D Audio - Asus Xonar DG
   Hail Sithis!
https://linustechtips.com/topic/102426-not-able-to-send-mms/#findComment-1369961
yea its on but still doesn't send. I just tried on an iphone 4s and it works. Its something to do with data on this phone..
Delltopia
https://linustechtips.com/topic/102426-not-able-to-send-mms/#findComment-1370032
have you checked your APN settings?
yup
Delltopia
https://linustechtips.com/topic/102426-not-able-to-send-mms/#findComment-1373899
