best number of fans
Nitsuj
so im building a pc, ryzen 5 2600 and a gtx 570.. would 1 fan be enough? the cpu cooler is a wraith cooler that comes with the cpu.
thanks!
The more fans the better.. but the bigger question.. spending money on a new CPU with an 8 year old GPU?
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
@Skiiwee29 thanks for catching that! i don't know, but what gpu i meant was the one thats newer and is close to the 1050 ti
so the AMD RX 570?
"Black Out"
Just now, Skiiwee29 said:
so the AMD RX 570?
yes... just now realizing there is a BIG difference
ok, thats much better than a GTX570 lol, a card that was released back in 2010 or 2011 time frame. But regardless, on your initial question, the more fans the better. This will allow you to run them at lower RPMs and allow you to keep good air flow over your components and keep them supplied with fresh air instead of stagnant air that can happen with only 1 or 2 fans instead of like 4 or 5.
"Black Out"
What case are you using? The most recommended setup is 2 in, 1 out. You can surely do with single fan exhaust, but just adding 1 intake at front is better already.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
54 minutes ago, Nitsuj said:
cougar mx330
The included stock case fan should be enough but adding a front intake could help lower temps.
