Cooler i7 7700k
L4SeR
Hi there! I want to upgrade from my i5 7600k to an i7 7700k. I now have the Bequiet pure rock 150w as the cpu cooler. will this be enough for the 7700k? because I have seen a lot of people complaining about the temps of the cpu. I have a limited budget thats why i won't upgrade to a 8th gen cpu.
Thanks in advance!
Thanks in advance!
yes it will be more than enough
You should be able to overclock a little. What's your current clock speed?
Primary PC:
Its hot chip, but so is everything Intel after Ivy. Pure Rock is better budget cooler, but well capable. Even for OC. You can always control voltages which are one of main reasons why latest Intel chips appear so hot for normies.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
