it will cool it. Other wise why would they put it with the CPU?
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/102276-haswell-stock-cooling/#findComment-1367887
No need to be dicks guys.
https://linustechtips.com/topic/102276-haswell-stock-cooling/#findComment-1367897
I wasn't trying to sound like a dick, didn't mean to come off like one
https://linustechtips.com/topic/102276-haswell-stock-cooling/#findComment-1367903
I'd upgrade to a better cooler. Mine got noisy after a few weeks.
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
https://linustechtips.com/topic/102276-haswell-stock-cooling/#findComment-1367944
I'm using the stock cooler with my 4670k and it's fine. Even under max load temps are ok. Just don't overclock as people have said above. I haven't found the noise to be a problem, but maybe that's just my case as it has soundproofing :)
NZXT H440+ 2015 Edition (Black/White) || i7 6700k @ 4Ghz || NZXT Kraken X61 Liquid Cooler || EVGA GTX 980ti SC || 16GB Kingston HyperX 2666MHz DDR4 || MSI Krait Gaming Z170A Motherboard || EVGA 750W 80+ Gold Modular || Corsair M65 RGB Mouse || Kingston HyperX Cloud Gaming Headset (White) || Steelseries Apex Raw Keyboard ||  Acer XB240H 1080p 144hz 24'' GSYNC Display || Windows 10 Pro 64 Bit
https://linustechtips.com/topic/102276-haswell-stock-cooling/#findComment-1367973
The reason why everyone is against stock ones is noise. Since that doesn't (yet) bother you, you'll be fine with stock cooler. If you get annoyed to noise, 212 is most suggested cheap cooler in here.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/102276-haswell-stock-cooling/#findComment-1372891
it will keep it cool if you have good airflow in your case but there are far better solutions for a cheap price like the CM Hyper 212 EVO.
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
https://linustechtips.com/topic/102276-haswell-stock-cooling/#findComment-1377779
