I have just made a computer about an hour ago and after booting it on ONLY the motherboard lights turn on! Right now there is no GPU as I will buy that later, but WHY is it still acting like this? My PSU is pretty basic so that could be the problem, but my specs are here:
  -asus rog x470-i
  -16gb ddr4 trident z
  -700W MasterWatt Lite PSU
  -Ryzen 7 2700x
  -NVMe 250gb
  -2tb HDD
All my fans (except CPU fan) are on a fan hub which is from the PSU, and is powered by Molex, but even the FANS dont turn on, this doesn't make any sense as this would mean that the Molex connectors arent working either, but how could this be?
There is always the chance that the PSU is faulty, but how exactly could I be sure? After all, the mOBO lights turn on?
What else problems could there be?
How can I fix this?
Plz help me... This is my first build and this is the first build and I am very confused...
https://linustechtips.com/topic/1022469-help-me-pleeaasee/
7 minutes ago, Teddy07 said:
The r2700x has no ipgu according to a quick google search. Please double check if that is actually true because you need a gpu if it is
But then that still doesn't explain why the fans dont turn on, as its not connected to the mOBO anyways...
https://linustechtips.com/topic/1022469-help-me-pleeaasee/#findComment-12201777
What fan hub? The fan hub probably needs to be plugged in to the motherboard as well as the molex. Read the manual for further instructions.
As mentioned the 2700x does not have integrated graphics so you won't be able to use the system without a graphics card.
That Masterwatt Lite isn't a good PSU, and you don't need 700W. What graphics card are you getting? Would be better off with a good quality 550W rather than a crappy 700W.
https://linustechtips.com/topic/1022469-help-me-pleeaasee/#findComment-12201790
Sounds like your hub is faulty or the psu
or maybe the  motherboard recognizes the lack of gpu and just wont start propertly?
Specs
I7 9700k /  Hyper 212 LED / Asus Prime Z390/ 16 GB HyperX Predator RGB 3600 MHZ  / Gigabyte 1080 Ti OC / NZXT H500i / Cooler Master V1200W /
Gear Headset G430 / Mic BM 800 / Keyboard Razer Blackwidow Chroma Ultimate / Mouse Razer Deathadder / Mousepad Razer Goliath Largest /
Monitor Setup 24U2414H 1080p 60hz x2 / S2417DG 2k 165 hz G-sync
Storage Samsung M2 970 EVO 500GB / WD Gold 1 TB 7200 RPM
https://linustechtips.com/topic/1022469-help-me-pleeaasee/#findComment-12201799
29 minutes ago, RandomGuy1677 said:
-asus rog x470-i
If you just have a gpus and once this?
My mistake it's a motherboard
https://linustechtips.com/topic/1022469-help-me-pleeaasee/#findComment-12201800
Its a simple 3-pin molex fan hub which comes with the mini ITX
So is it normal for it not even to turn on the screen? I'll get the graphics card later, but why is it that the computer fans wont turn on or anything like this? BTW fan hubs connect directly to the psu and have nothing to do with the mOBO.
I dont expect the bIOS to turn up, but I wanted to see if everything actually turns ON
https://linustechtips.com/topic/1022469-help-me-pleeaasee/#findComment-12201810
Mini ITX what? Mini ITX is a form factor and doesn't help identify the fan hub. Read your case/fan hub manual and it should walk you through how to install the fan hub.
That's expected when you don't have any form of display adapter.
https://linustechtips.com/topic/1022469-help-me-pleeaasee/#findComment-12201821
Just now, Ryanwake said:
At first I thought Asus rog470i was a graphics card, because the Asus and the 470.
Then I Googled it and apparently that's a motherboard, maybe I'm wrong again it could just be both
You're thinking of the AMD RX 470 graphics card. OP as a X470 Motherboard by Asus. Completely different things.
https://linustechtips.com/topic/1022469-help-me-pleeaasee/#findComment-12201822
Sorry Spotty, it comes with the NZXT Manta case
https://linustechtips.com/topic/1022469-help-me-pleeaasee/#findComment-12201826
2 minutes ago, RandomGuy1677 said:
Thats what I'd been thinking, but then why the mOBO lights turn on but NOTHING else?
So your current setup is
PSU -> Fan HUB - > Fans (not spinning)
PSU -> Mobo -> Lights, but does the cpu fan spin or aio fans whatever you use
Specs
https://linustechtips.com/topic/1022469-help-me-pleeaasee/#findComment-12201828
It needs to be plugged in to the motherboard in addition to the molex power connector. Here's the instructions in the MANUAL
https://linustechtips.com/topic/1022469-help-me-pleeaasee/#findComment-12201836
Wait a minute.... In the manual it says that it should spin at full speed WITHOUT the pwm connecting, but its completely static, but I'll try it anyways..
That's when plugged in to a 3pin non PWM fan connector on the motherboard.
See pages 12 and 13 of your case manual for installation guide.
The connector I've highlighted red needs to be plugged in to a fan header on the motherboard, preferably a 4pin PWM fan header such as CPU_Fan
https://linustechtips.com/topic/1022469-help-me-pleeaasee/#findComment-12201846
Connected, wont do anything
https://linustechtips.com/topic/1022469-help-me-pleeaasee/#findComment-12201857
