Hello,
I have my 6-7 year old computer with (Gigabyte h55m-ud2h motherboard, i7 870 2,93GHz, 8 GB of ram, and Nvidia GTX 480).
My GTX 480 died and I am thinking of buying GTX 1070.
So I am interested if my processor will be enough for the new video card.
Also if this processor is too old will my existing motherboard will be good for the better processor ( What processor you could recommend for the setup)
Thanks
https://linustechtips.com/topic/1022247-need-help-with-the-computer-upgrade/
When it comes to an old i7, it varies. What's your game library look like? Also, given your old graphics card, I'm assuming your performance target is 1080p 60, and if that remains unchanged, I'd recommend an RX 570 or 580 from eBay.
Primary PC:
PSU tier list
How many watts do I need?
6 minutes ago, Danielius48 said:
Hello,
Thanks
Welcome to the LTT forums! I would not recommend the 1070 for that aging CPU, I would recommend a 1050, and maybe just maybe a 1060. Otherwise you are just wasting money, unless you plan to upgrade your CPU as well
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
13 minutes ago, Danielius48 said:
Hello,
Thanks
CPU will bottleneck the GPU in anything that isn't pretty trivial to run. A RX 570 or a 1050 is about as much as makes sense. Beyond that, you'd need a full system upgrade. Used 970 would work as well.
Unless it's used don't go with a 1070. They are selling for more than the new RTX 2060 which is a better graphics card. But, unless you're planning on going to 1440p or super high refresh rate 1080, your cpu will bottleneck. The Ryzen 2600 is a nice affordable option right now for cpus.
