So my dad got mad at me and started pulling out the cables from my com (USB cables, LAN cable, Graphics cable)
And he kinda pulled the whole DVI cable out with the screws still in the graphics card, meaning the cable was wrecked.
I powered on my com without realizing that, and naturally only my second display outputted a signal.
I then took a spare guaranteed working DVI cable and swapped it with the wrecked cable.
It would boot into windows but my main display will not display anything but windows still thinks there are two displays.
I decided to swap the DVI ends and eventually reseat the graphics card
After I did that, my mobo still will not POST with my original Titan X installed.
Normally if POST is successful, my keyboard will start lighting up and showing the default animation, as will my mouse.
In this case my keyboard only did the animation for 1 sec before just stopping, and my mouse does not light up at all.
Also there are two short beeps from the mobo speaker after a long time and one short beat every subsequent 20 secs. No display on either display.
Swapping the Titan X out for a spare RX 580 gives me POST and display BUT only on my HDMI second monitor.
Note: resetting CMOS does not work
I decided to reset CMOS and change the default VGA device back to the motherboard and it booted with the Titan X installed BUT of course the display was from the VGA cable connected to the motherboard
Windows loaded and showed a Code 43 for the Titan X
I'm just confused
How can a card just die like that
I suppose my monitor is just fked
Any suggestions?
Specs:
2 x Xeon X5690 (12C 24T)
Supermicro X8DTL-i
64GB SK Hynix PC3-12800R RAM
Crucial M550 512GB SSD connected to Asmedia 106X Sata 3 PCI-E card in AHCI mode
Creative Sound Blaster X-Fi Elite Pro + external I/O console (for headphones and mic)
Dual Intel NIC teamed and connected to Netgear R9000 X10 router
Windows 10 Pro 64bit latest build
Both CPUs are liquid cooled and idle around 25C, load MAX 50C
ASUS GTX TITAN X with EVGA 980Ti aftermaket Hybrid cooler
ASUS RX 580 Dual OC
Crossover 27Q 1440p (FIRST MONITOR CONNECTED BY DVI)
DELL SE2417HQ (second monitor connected by HDMI)
Matrox G200EW onboard motherboard display output
4 port USB 3.1 PCIE card
Creative Sound Blaster VX 5.1 for speakers
Topre REALFORCE RGB Keyboard
Corsair Glaive RGB Aluminum Mouse
BIOS settings that I changed (latest BIOS installed)
PnP OS -- ON
LAN OPTION ROM -- OFF
C-STATE -- OFF
PCI LATENCY TIMER -- 32
Main Rig: CPU Intel Xeon X5660 (4.55Ghz @ 1.45v) / MOBO Asus ROG Rampage III Extreme / RAM 16GB Corsair Vengeance LPX1866 MHz / CPU COOLER ID-COOLING Frostflow+ 240 / GPU EVGA Titan X Hybrid (+630 core + 400 memory) / CASE Cooler Master CM 690 II Advanced + transparent side panel / SSD Crucial M550 512GB / PSU Cooler Master Silent Pro Gold 1200W / DISPLAY 1440p monitor / KEYBOARD Topre Realforce RGB / MOUSE Corsair Glaive Aluminum RGB / SOUND Creative Labs. X-Fi SoundBlaster Elite Pro / ROUTER Netgear R9000 X10 Wireless ad / OS Windows 10 Pro / DRIVING WHEEL Logitech G27
Web Server Rig: CPU 2x Intel Xeon X5680 / MOBO Supermicro X8DTL-i / RAM 64GB (2X32GB) SK-Hynix ECC LRDIMMs / CPU COOLER ID-COOLING Frostflow+ 120 + Corsair H50 AIO / GPU MSI GTX 1070 Gaming X (+250core +300 memory) / CASE NZXT Lexa S / SSD Kingston 120GB / HDD 4 x 3TB WD RAID 6 / PSU Enermax MaxRevo 1500W / DISPLAY 900p monitor / KEYBOARD Logitech / MOUSE Logitech
Actually Portable Laptop: HP Spectre x360 15' (Late 2018) / i7-8750H, 16GB RAM, 512GB SSD, GTX 1050Ti MaxQ, 4K Display / KEYBOARD Ducky One 2 Mini / OS Linux Mint 19 Cinnamon / WIRELESS ADAPTER NETGEAR A6210 USB 3.0
Bed Laptop: ASUS VIVOBOOK 15 / i5-8250U, 8GB RAM, 1TB Toshiba HDD, UHD 630, 1080P Display / OS Linux Mint 19 Cinnamon
Backup Rig: CPU Intel Xeon X3470 (4Ghz @ 1.4v) / MOBO MSI P55-GD80 / RAM 16GB HyperX 1600Mhz / CPU COOLER ID-COOLING Frostflow+ 120 / GPU Sapphire R9 270X (+150 core + 200 memory) / CASE Cooler Master Elite 343 SSD Crucial MX150 250GB / PSU Seasonic SS430-GB / KEYBOARD Logitech G910 Orion Spark / MOUSE Logitech / DISPLAY Dell SE2417HGR / OS Windows 10 Pro / WIRELESS ADAPTER
TP-LINK Archer T6E PCI-E
Server 1: DELL POWEREDGE 1950 / 2x Intel Xeon E5450, 16GB ECC, 4x 3TB Western Digital (Various) 7200RPM SATA HDD in RAID 6, GT 640 / DISPLAY Lenovo L2251p
Server 2: DELL POWEREDGE 1950 / 2x Intel Xeon E5420, 8GB ECC, 2 x 160GB SAS, GT 210
https://linustechtips.com/topic/1022231-graphics-card-problem-just-need-help/
So you can get into OS with the titan installed?
Primary PC:
PSU tier list
How many watts do I need?
unplug the DVI? that port is probably properly wrecked. if it dosnt boot without the DVI plugged in there might be a short there
Builds:
ONLY using the mobo onboard VGA and with onboard VGA selected in the BIOS
yeah it does not boot with just the HDMI plugged in, or if the DVI is plugged in
then ther DVI port and potentially more of your card took some damage, you could try taking the cooler off the card and looking for anything that dosnt look right. burnt or loose components or such. your card is likely hardware damaged, it could be as little as needing to cut the DVI connector of the card all the way to dead silicon tbh
Builds:
hmm yeah, this is the worst thing i could imagine, darn having to replace such an expensive card and a monitor. ??
how though, does the card even spoil? by right some exposed cables that is touching nothing should not damage a card THIS bad...  IDEK
the pulling on the DIV connector on the card could have damaged that, maybe its even ripped off the board.
Builds:
