Audio Splitter (Newbie needs help)
With an audio splitter like that there is no way to switch outputs, that splitter just turns one audio output into two. You would need a 3.5mm switch to actually change the outputs.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
17 minutes ago, FalconWingz said:
so i want to change from my speaker to headphones in one button
so i bought an audio splitter, i plug my speaker and headphone
but when i do that, the audio came from both of the speaker and headphone
how to make only one of them sounds
thanks
A splitter just duplicates the input.  If you want one to work and not the other you need a switch, like this:
https://www.amazon.com/3-5mm-audio-switch-AB-selector/dp/B01L5LDM9I
Or just unplug the one you don't want.
