System for relative
Go to solution Solved by Fasauceome,
Yes if you're getting used parts
Is this good 1080p gaming system for a relative?
CPU: i7 6700K 4C/8T LGA1151 CPU @4.0Ghz (Likely to OC to higher speed)
GPU: EVGA GeForce SC GTX 1060 6GB
MOBO: GIGABYTE Z270N Gaming 5 Mini-ITX
RAM: DDR4 2666 16GB (2x8) RAM
CPU Cooler: Corsair H55/Corsair H60
PSU: EVGA 600 BQ 80+ Bronze Semi-Modular
Case: DIYPC-F2-P mATX MiniTower
SSD: Crucial MX500 500GB
HDD: Seagate Barracuda 1TB
https://linustechtips.com/topic/1022030-system-for-relative/
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1022030-system-for-relative/#findComment-12197376
33 minutes ago, AYDANN6ix9ine said:
It is a good system but you could get a better answer if you shared more information, like what games will be played, what the budget is, monitor being used...
https://linustechtips.com/topic/1022030-system-for-relative/#findComment-12197431
