1 minute ago, theohiort said:
60$ left
Did you forget a zero?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1021904-build-help/#findComment-12196305
4 minutes ago, theohiort said:
No? I don't have 600 bucks dude.
Why would you buy a 2080 Ti and leave only $60 for a CPU and motherboard? You're gonna have to get a pretty bad CPU if your budget is that low.
Look for cheap old Xeon quad core CPUs and buy any cheap compatible motherboard.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1021904-build-help/#findComment-12196333
The only CPU that's modern you can get for 60 is the athlon 200GE
You're gonna want to save up more like $250 for CPU and mobo
Primary PC:
PSU tier list
https://linustechtips.com/topic/1021904-build-help/#findComment-12196358
That's like buying a brand new Rolls Royce and saying you only have 6 bucks for fuel...
Desktop benching:
https://linustechtips.com/topic/1021904-build-help/#findComment-12196375
Just now, theohiort said:
Well the car would be the important part right? The other parts don't really matter to me at all.
So you bought a graphics card just to look at it? Then don't buy a CPU, problem solved.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1021904-build-help/#findComment-12196416
3 minutes ago, theohiort said:
Well the car (or videos card in this case) would be the important part right? The other parts don't really matter to me at all.
$60 worth of CPU, ram, and Mobo will make that 2080ti run like a GeForce 210
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/1021904-build-help/#findComment-12196443
Return it and we'll help you build a PC around an RTX 2060.
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/1021904-build-help/#findComment-12196448
In case you're confused by our responses, we're not being elitists by saying you need an expensive CPU to be considered a gamer or anything, you literally need an appropriate CPU to handle that graphics card. It can't be put to good use without other quality components.
Enhancing the car example a bit, the 2080 ti is like the chassis of a Rolls Royce, a $60 CPU would be like putting a 2 cylinder engine inside. It'll look great and run like crap.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1021904-build-help/#findComment-12196627
yeah but having little fuel the car is hardly useful. Using so much money on a 2080ti but cheap out on everything else means the 2080ti get bottlenecked by in this case, the CPU, all the time and cannot show its potential as a GPU. You might not care, but your GPU does.
Desktop benching:
https://linustechtips.com/topic/1021904-build-help/#findComment-12196837
Well, thanks for nothing guys. I thought I asked a simple question, guess not. Just gonna get the cheapest ones I can find at the local store.
https://linustechtips.com/topic/1021904-build-help/#findComment-12196957
You got the correct answer, not the one you wanted to hear, sorry.
Black Knight-
Daughter's Rig;
https://linustechtips.com/topic/1021904-build-help/#findComment-12197372
There is a lesson to be learned here.  A balanced build will out perform an unbalanced build any day of the week.  You made a mistake, that's okay.  If you can, you really should return the 2080ti for something more reasonable.  The 2080ti is THE most powerful consumer card on the market today, pairing it with anything less the the top end CPU, RAM, Mobo, and cooling solution is a complete waste of money.  You're talking $300-$500 for the CPU, $150-$300 in RAM, a $200 mobo, $100-$200 for cooling.  It's not a simple plug the RTX2080ti into an NES and you will have 4K graphics.  You need the appropriate components to make it work.
I could, and am more than happy to, put together a parts list for you of an entire build that will cost you the same as what you paid for your 2080ti plus your $60 that will stomp any system you can think of building with a 2080ti and $60.
What you are failing to see is that every single person who has responded to your post, wants to help you.  We genuinely want to help you get a system that's going to get you gaming.  The people here are very experienced, and very open to sharing their knowledge.
https://linustechtips.com/topic/1021904-build-help/#findComment-12197562
