I'm am upgrading my PC since the last one is now about 7 years old, I primarily use it for playing games and it does do that well, but as of late to play some of the games I've gotten into I only get around 20 fps at medium or low settings. This build:
is about where I am with being able to do what I would like now as well as improve more easily in the future unlike my last one which I haven't done any upgrades except for a wifi card when lan wasn't available. Any input to improve my build for price to performance would very much appreciated. As for peripherals I have mouse and keyboard that I have upgraded throughout the years and the monitors are to be desired but I can live with the two I have until I have more capital to procure better ones.
https://linustechtips.com/topic/1021735-need-input-on-these-specs/
The PSU is complete overkill. You can use a HDD for secondary storage and it'll be so much cheaper. You don't need that kind of cooler for that CPU. You can use something like a Dark Rock Pro 4 from Be Quiet! to spend a little less and get something quieter. You don't need to spend so much on the motherboard either, that it quite a lot there.
USEFUL LINKS:
PSU Tier List F@H stats
Really solid build, I just have an issue with almost every other main component costing more than the CPU.  970 EVOs are wasted on gaming.  Watercooling that CPU is a waste, the stock cooler does great.
Unless that CPU is just a placeholder for the next gen, that PC is priced for an Intel OC'd to death setup.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
so would swapping to an i5 or i7 be a better set-up instead of a Ryzen? My last computer is amd so i figured to go that route this time too, since i didn't have any issues with it.
8700K or better.
I'd cut the 970's out and put in 860's or similar.  You don't need NVMe.
Less PSU too.
More GPU.
OnePlus Ecosystem:
3D Printing:
1tb for the second drive is just not enough, so my suggestion is to buy a big HDD instead.
500gb ssd + 3tb (or more) HDD should be enough, remember 1 game can cost you 50gb or more, not including the updates.
RTX 2060 is only $50 away, i would just delete the $20 each extra fans to get that.
Fans should be bought after you build the system, the case should provide enough airflow, and Ryzen is not a hot cpu.
The PSU should be 500-650 watt, more than enough to drive the whole system.
11 minutes ago, jstudrawa said:
8700K or better.
Less PSU too.
More GPU.
So something like this?
but with a 2060 directly from nvidia. pcpartpicker doesnt have them on their site
40 minutes ago, Xasriel said:
What monitor are you gaming on ?
Go with Z390 chipset for a 9th gen cpu. The Z370 might need a bios update to work.
You would need to buy some fans as that case doesn't have any pre-installed.
How much is the 2060 gpu ?
My monitors are pretty bad, but for me that's okay for now. They are 20" 55hz 1080p. The 2060 from nvidia is 350 and I did find an msi z390 board for about the same I thought the same with the case I had added fans someone said to scrap them until the computer is build, but I'll add them back to the cost
If you are not fussed about Ray Tracing etc then this GTX 1070 is $299 after rebate. Not quite as powerful as the 2060 which is more or less on par with a 1070 ti but at least you don't lose any VRAM. And for 1080p it is a good gpu. Will even do ok at 1440p.
https://www.newegg.com/Product/Product.aspx?Item=N82E16814125875&ignorebbr=1&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker, LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Yeah for Z390 Gigabyte or MSI would be my suggestion. The Asus boards are not that great for the most part on Z390.
You would need to buy some fans if going with that case otherwise you won't have any airflow. You need some intake and exhaust.
This is what I have ended up with any thoughts?
OnePlus Ecosystem:
3D Printing:
I would probably try to save some money everywhere and would try to fit in a 24", 144 hz, free sync, 1080p monitor.
Investing in the gaming experience. You would maybe have to step down a gpu tier but your overall setup would match better.
Just out of my head go ryzen 2600 and save 80 $ on cpu, 40 $ on a cooler and 60 $ on the motherboard, take the 10 % or so performance hit and buy a monitor with the difference.
You could save some more on case and ssd.
Maybe even get 1440p gaming.
When I am at home I will make you a config.
But maybe @LukeSavenijehas something for you
