Lower speed despite having higher bandwidth.
Go to solution Solved by Newbie0,
Fixed it. Router was the culprit.
Hi,
My ISP was meant to give me at least 4 mbps.
But recently it’s capped @ 3 mbps.
I went to their office & they literally changed the allocation for my ID from 8 to 10 mbps.
They changed the optical fibre from their office to my home( that's what they said. Not sure), changed the old optical to cat-5 converter & installed something called ONU.
Still I’m getting 3 mbps.
I've got 4 Mbps but that was two months ago. After that not a single bit over 3mbps.
It looks like their changes isn't properly applying.
What’s the issue & how can I fix this?
They can’t figure out the issue.
( my ISPs networking knowledge is not that good. In some cases I know better than their workers )
Thanks.
https://linustechtips.com/topic/1021696-lower-speed-despite-having-higher-bandwidth/
