Okay so I recently installed a adata SX8200 240gb.
i partitioned the memory and whatnot then went into bios because I heard you needed to enable a genie to decide how the m.2 reacts.
so I went to bios searched m.2 and the first thang that popped up was “ m.2 Optane genie” so I enabled and restarted my pc. I am stuck in an endless cycle of starting windows only to find a blue screen.
Disabling the genie did not help
https://linustechtips.com/topic/1021554-m2-nvme-adata-blue-screen-help/
wrong option.... its not optane.....
revert settings / reset bios if needed
on next startup, in bios or disc management, if you see the ssd, you are good to go
