Please Help! Corsair Problem!
1 minute ago, Ashiok said:
I have the Lightning Node Pro. Its plugged in. Does it need to be connected to the MOBO or something?
You mean the Lighting Node Pro? I'd imagine. Where do you have it plugged in now?
"uhhhhhhhhhh yeah id go with the 2600 its a good value for the money"
Just needs a USB connection. Either through a 2.0 header or a USB port.
Install Corsair Link and see if the Node Pro shows up there.
If it doesn't, try another USB header/port.
If that doesn't work, try another version of iCue/Link.
If none of that works, RMA the Node Pro.
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
I have a cord that goes from lighting node pro to the corsair fan led hub. Then I have the fan rgb plugged into that and both hubs plugged into sata.
I dont have a wire for a usb 2.0. Could you link one tha tI could buy?
The Node Pro comes with one. Otherwise any USB 2.0 cable with a mini-B end will work.
Come Bloody Angel
Pale battered body
Fierce Bloody Angel
Pyo.
The hub comes with all cables you need. Here's pic from Node Pro manual:
Showing you how to connect USB from Node Pro to your mobo.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
